Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Tire noise on 2006 Honda Civic
Old Jul 4, 2013 | 06:43 PM
ManInBlack's Avatar
Default Tire noise on 2006 Honda Civic
I have a 2010 Civic that I bought new and it is a quiet and smooth car so when I recently bought a used 2006 for a work car for my wife I noticed a fairly load whining or howling noise coming from the rear when driving on smooth roads. When I test drove the car it was on a tar and chip road so it wasn't noticeable . I thought it was wheel bearings but after I installed new bearings it was still there . Even though the tires are new and look fine I felt it had to be bad tires on the rear so I swapped them out onto my 2010 and sure enough the 2010 had the same noise with those tires. They are Uniroyal Tiger Paws and my question is , have there been any complaints or recalls with these tires. Since the previous owner bought the tires is there still a chance that Uniroyal will back up the tires ? They are obviously defective .
Old Jul 4, 2013 | 08:36 PM
m_shake's Avatar
Default Re: Tire noise on 2006 Honda Civic
Some tires make more noise then others, fact of life. Contact uniroyal about the problem or just buy better tires. Only other thing I can think of is the alignment is all ducked up and caused a weird wear pattern thus making noise.
Old Jul 8, 2013 | 04:07 AM
ManInBlack's Avatar
That's what it was " THE DUCK STRUCK" The tire shop showed me how to feel the tread for uneven wear. Whats funny is that you couldn't see it because it was so slight but you definitely could feel it. Bought two new same brand tires and the problem is gone. I'm taking it for front end check.
Old Jul 9, 2013 | 05:22 AM
DaveSi677's Avatar
I know the last time I went to Honda they did an alignment and ruined my rear tires which cause a similar noise that you were experiencing... I even asked them not to do it because I had specific settings.
Old Jul 28, 2013 | 05:49 PM
compressro's Avatar
I went through the same issue, it was totally alignment and control arm related. Replaced stock control arms through the honda recall and new tires, problem gone.
Old Aug 21, 2013 | 03:46 PM
herebyproxy's Avatar
Engineering fault on 2006 and some 2007 civics. The rear upper control arms are too short causing the tires to cup and wear uneven. I didn't realize it was a recall but it was definitely a TSB. I bought my used 2006 the first of this year and had the howling noise from the rear. I did the research and found out what the problem was and the dealership fixed it no charge. If they replace all 4 tires, replace the control arms, and align it.....it's about 1000.00 unless Honda or the dealer helps you out.
Old Aug 23, 2013 | 05:12 AM
vladd's Avatar
It's not a recall, but there is a TSB out for it.
Old Aug 23, 2013 | 07:18 AM
av911's Avatar
Pretty sure it was a recall, as I received a letter from Honda regarding this issue.
Old Aug 26, 2013 | 01:08 AM
Cheeech's Avatar
Same here, went to my local honda dealer, they replaced my control arms with the new ones free of charge. btw the new control arms have the letter "C" stamped on them, so if you're not sure which control arms you have, check for the stamp.
Old Aug 26, 2013 | 08:44 AM
ManInBlack's Avatar
Is Honda still replacing these control arms on cars as old as 06 and 07's at no charge ?
Old Aug 26, 2013 | 11:10 AM
Cheeech's Avatar
Yes sir. Mine is an 06 and were replaced 4 days ago.
Old Aug 26, 2013 | 03:02 PM
av911's Avatar
No questions asked?
Old Aug 26, 2013 | 10:11 PM
Cheeech's Avatar
No questions asked?
No questions asked. I just told them I received a letter regarding the settlement for the faulty control arms and they said to bring it in. I did and they replaced them.
Old Aug 27, 2013 | 04:37 AM
ManInBlack's Avatar
Where do I look for the stamped letter C ? Might be hard to see with rust coating.
Old Aug 27, 2013 | 01:22 PM
Cheeech's Avatar
I haven't been under the car since they have been replaced so I can say exactly where. Ill try and snap a pic and post it since I couldnt find anything on google.
Old Aug 27, 2013 | 11:49 PM
Cheeech's Avatar
Here is a quick snap shot I took. The stamp faces towards the front of the car.
Old Aug 28, 2013 | 01:51 PM
Brettster55's Avatar
The motor mounts are hard to visually inspect on our cars, but its worth a shot
Old Sep 2, 2013 | 04:46 AM
ManInBlack's Avatar
Thanks , I appreciate it. I'll get under there and check it .
Old Sep 2, 2013 | 02:26 PM
DELuth's Avatar
To clarify....
That picture is NOT the stamp. that is ink. The stamp is just that, a stamped recess in the metal in the shape of a C. The stamp is small, about the diameter of a pencil. The older control arms had the stamps AND the inked Cs, but the newer arms are missing the big white inked C and it also could be worn off of older arms. Just because it doesn't have the big white C doesn't mean they are the old arms. I will post a pic if I can find one.
Old Sep 3, 2013 | 01:33 AM
Cheeech's Avatar
Originally Posted by DELuth
To clarify.
I'm sure you're right, after reading different threads on different forums that is what I was lead to believe. You say that the new arms don't have the inked c on them but that photo is of the new arms that were replaced. So Im alittle confused on that part since my new arms do have the ink c mark.
Old Sep 3, 2013 | 04:26 AM
DELuth's Avatar
I guess I worded that badly. The original arms had no marks. The replacement arms used to have inked Cs and stamped Cs. The newer replacement arms seem to not have the inked Cs and just the stamped Cs as the last two sets I installed did not have the inked Cs.
Old Sep 3, 2013 | 06:16 AM
TheMuffinMan's Avatar
He knows where you live!
Which 'Tiger Paws' are installed? If it's a set of the Snow and Ice ones I wouldn't be surprised you're having noise.
http://www.tirerack.com/tires/TireSe...ype=bestseller
Personally I only grab tires with good user reviews on the forums and TireRack. I've got an inkling those Uniroyals are from some random local shop. TR doesn't even stock them...
Old Sep 25, 2013 | 01:07 PM
94EG8's Avatar
Seagull Management
I just installed a set yesterday that didn't have the inked Cs I'm guessing that's why there's a new part number (A01 vs A00)
LOWTECHMAN
Jun 9, 2013 08:53 AM
FitsMe
Honda Fit
May 21, 2012 05:07 AM
jonssonar
Nov 27, 2010 09:45 AM
aznromeo4u
Jun 28, 2010 07:08 AM
ken9
Apr 25, 2009 12:48 PM
