can't push strut fork up
Old Jul 3, 2013 | 11:56 AM
wannabemechanic's Avatar
Default can't push strut fork up
I am changing all of my ball joints and tie rod ends. I got everything disassembled and replaced on the passenger side, but now i can't push the strut fork up to bolt it together. It is pushed down past the suspension and won't go back up. I have tried a spring compressor, jack under neath and brute force. Any tips besides killing myself (which seems like the next logical step against my better judgment).
Old Jul 3, 2013 | 12:08 PM
TheMuffinMan's Avatar
He knows where you live!
Default Re: can't push strut fork up
Have you removed (unbolted) the sway bar endlinks from the control arms?
Old Jul 3, 2013 | 12:09 PM
MAD_MIKE's Avatar
MM Gruppe B
You were replacing the balljoints and unbolted the shock fork? No need to do that. What year Accord do you have? It could be that the shock may have jammed while extended, had a Monroe shock do that to me. You may have to dissemble the coilover to coax the shock to work again.
Were you only replacing the BJs?
Old Jul 3, 2013 | 12:31 PM
Good call on that one too, I was assuming they had the fork attached correctly with the shock first prior to doing anything. He may be trying to shove the stuff in at slightly the wrong angle.
Old Jul 8, 2013 | 07:21 AM
I got it. I was trying to pull everything up. I stood on the rotor and it went down to where i needed the holes to line up. Thanks for all the suggestions
Old Jul 8, 2013 | 12:47 PM
808k20a2's Avatar
so stepping on the rotor gave the suspension more slack to fit into the top mounting points. lol! I learned this with my hatch along time ago.
todd bayliss
Suspension & Brakes
Sep 26, 2009 09:39 PM
jimep386
Dec 25, 2006 08:49 PM
four o two
Jan 6, 2006 05:55 PM
rudeman85
Sep 28, 2004 01:38 PM
akaEsCo01
Jul 28, 2003 10:33 PM
