d16z6 tensioner question
Old Jul 3, 2013 | 11:09 AM
14psi's Avatar
Default d16z6 tensioner question
I was wondering if on a d16z6 engine do I have to remove the lower timing belt cover to loosen the tensioner bolt or is there a hole I can stick a socket wrench through?
Old Jul 3, 2013 | 11:16 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: d16z6 tensioner question
no....there is a hole above the crank pulley. It may/may not still have a round cover covering it.
Old Jul 3, 2013 | 11:22 AM
14psi's Avatar
thanks
Old Jul 3, 2013 | 11:25 AM
NVturbo's Avatar
O.G. triple O.G.
even though this is a D15B, it's the same setup as a D16z6. You can clearly see the "RED" colored bolt right above the crank pulley.
Old Jul 3, 2013 | 11:33 AM
14psi's Avatar
ok perfect now I can complete my head gasket job :D thanks again
Old Jul 3, 2013 | 11:41 AM
NVturbo's Avatar
O.G. triple O.G.
anytime....
vtec4max
Oct 26, 2009 05:28 PM
crxblues
13
Apr 6, 2009 04:47 AM
crxblues
Mar 18, 2009 05:23 PM
88crxdxfastwhip
Jun 13, 2008 11:56 AM
