2 b16a2 bottom ends pr3 pistons on ls rods and more
Old Jul 2, 2013 | 11:15 AM
ek9kbomb'd's Avatar
10 Year Member
Default 2 b16a2 bottom ends pr3 pistons on ls rods and more
if interested in any parts please pm or text 630-677-8779
b16a2 complete bottom end minus alternator comes with everything the guy I got it from said it had a spun rod bearing but im not sure vin intact $100 obo
b16a2 block cylinders look good comes with oil pump, rear main, crank, water pipe, sensors also has vin intact still $50
ls bottom end comes with water pump, oil pump, timing belt rear main and crank needs new thrust washers vin intact still $40
pr3 b16 pistons on ls rods good for bumping up the compression on a ls bottom end all 4 $50
obd1 b series alternator good condition $40
ek mudflaps 1 used other 3 are new still $60
turbo downpipe with flex pipe and 2.5" flange $50
ktuned ac/ps delete kit comes with everything, hardware and belt and all bracket and alternator pulley let me make it clear though that the piece that goes in the center to adjust it broke but still functions perfectly fine all I had to do was use a pry bar and pry it up a little to tension the belt and tighten the pulley and it worked perfect $100
gsr front calipers and brackets good condition $40 for the pair
k20 vision carbon fiber coil cover $60
em2slips
Jan 27, 2010 01:38 PM
slayersluck
Dec 6, 2004 11:01 AM
BrokenLimits
Feb 10, 2004 02:34 PM
bojangs
Aug 28, 2001 09:45 AM
