SLICKS question..
I have a pair of Mickey Thompson slicks.
24.5×8.5 mounted on 13 inch LENSO wheels
Gonna mount them on a 89 Civic ef Stock obd1 b18 with Just intake and exhaust.
What rpm should i launch em at?
what psi should i run em at?
Full throttle launch? and yes im gonna be preloading as i dont wanna snap axles
From: Pensacola, FL and every Court House in Louisiana
Good luck with a slick that big!!! You really should be running a 22" slick. I am launching my eg hatch with a gsr swap at 6500-7000 with 23"x 8.5.
That is way too much for that setup, I let my buddy borrow my 24.5x8.5 on his i/h/e h22 swapped coupe and it worked well for him. He was launching around 7500 rpms on a stage 3 clutch and stock axles.
I'm not sure how much longer that would've lasted though.
yes stock axles
and exedy stage 1 clutch.
Im doing 15.4 on street tires
I wanna try and hit mid 14s or lower
Just need opinions and people who exp. with no prob.
@tuner eddy 60 ft time?
Those tires are way to big for that. Like stated you should be running 22's. If your set on running them leave a lot of air in them so the walls don't wrinkle. And launch it off the limiter lol
Definitely get some smaller slicks/radials. I'm willing to bet you will go a decent bit slower with that much tire. Especially if you still are using a LS trans lol
Thanks for your input guys.
Guess im just gonna look for smaller slicks.
@tuner eddy
My buddy was running consistent 15.3-15.4 on street tires
98 Ls integra with BC stage 2 cams, I/H/E Untuned
Ran 14.5 with 22x7x15 MH slicks
Im pretty sure ill hit mid 14s but will see.
@tuner eddy
