Re-pin 96-98 civic power door locks to 99-00
Old Jun 29, 2013 | 03:44 AM
adnoH671's Avatar
10 Year Member
Default Please delete this thank-you
Is it please delete this thread thank you
Old Jun 29, 2013 | 04:15 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Re-pin 96-98 civic power door locks to 99-00
Done this to YOUR car? And you think this why?
Old Jun 30, 2013 | 05:00 AM
adnoH671's Avatar
10 Year Member
I have done the conversion to my car, yes. I have been reading up on the conversion of the 96-98 Civics and without the proper floor harness, all that is needed is to wire it up from door to door, ground it and give it some power... Which is why I ask again if it would be possible to just re-pin the wiring into the proper areas where the 99-00 Civics EX/SI power door locks gets its power and connects to each-other from door to door, to stray away from actually cutting and running my own set of wires...
Old Jul 1, 2013 | 05:38 AM
kyden's Avatar
the connectors are the same, yes. just look in the ETM section of the service manual and the pinouts are there.
Old Aug 21, 2013 | 10:58 AM
KiNGDEE206's Avatar
sorry but i need this too, figured itll be better to bump this then create a new 1
i have a 99 ex coupe power everything
i replaced the WHOLE DOOR (due to a fat expensive fix for the door itself) w/ a 96-98 ex power door also, i notice the power locks DOES NOT WORK keeps blowing fuses
anyway to repin the harness (assuming repin the pins @ the door to frame harness plugin)
looked through my honda service manual at the ETM section, i dont see any pinout layouts
Old Aug 21, 2013 | 11:50 AM
kyden's Avatar
you can do 96-98 to 99-00, but not the reverse.
socale39
Mar 13, 2010 03:00 PM
junintegra2000
Jul 11, 2008 05:23 PM
vSz
Northern California (Sales)
Mar 29, 2008 03:38 AM
teamm_AP1
19
Nov 29, 2007 07:55 AM
