FS: 1995 Honda Civic DX Hatchback | Progress Tech. | SOHC VTEC | JDM | ITR |
Old Jun 28, 2013 | 06:05 PM
RussLaviolette's Avatar
Default FS: 1995 Honda Civic DX Hatchback | Progress Tech. | SOHC VTEC | JDM | ITR |
***No Trades*** ***No Trades*** ***No Trades*** ***No Trades****
Make: Honda
Model: Civic DX
Year: 1995
Motor: 1.6 SOHC VTEC D16A (JDM)
Transmission: Manual 5-Speed
Exterior:
~ JDM Stanley Clear Corners
~ HOP Radio Antenna Block-Off Plate
~ HOP Side Mirror Block-Off Plates (Driver and Passenger)
~ New Windshiled (01/09/2012)
~ JDM Long-LED Two-Piece Rear Wing
~ JDM SiR Tailgate
~ *** Undamaged Fenders Included *** (Not installed)
~ OEM Bumper License Plate Plugs Replaced
~ OEM Rear Wiper Delete (Will Include Wiper Assembly)
~ Windshield Wiper Delete (Will Include Wiper Assembly)
~ OEM Front Mudflaps
~ Windshield Washer Nozzle Delete (System Will Be Provided)
Interior:
~ Black On Gray
~ 94-97 Acura Integra Front and Rear Seats (Rear Seats Not Installed)
~ 1992 Civic Si Gauge Cluster
~ SONY CD Player
~ New OEM Shift Boot
~ Cargo Cover
~ New Fuse Panel ID Label
~ Manual Windows
~ Manual Locks
~ Dual Air Bags (Steering Wheel and Dash)
~ 6.5" SONY Door Speakers
~ Civic EX/ Si Dash Clock
~ *** All A/C Components Are Present But Not Functioning ***
~ *** HOT HEAT ***
Motor/ Transmission: * = Parts Have Less Than 6K Miles On Them.
~ *Solid* 1.6 Motor (10/10; No Smoke, Leaks, Knocks or Ticks)
~ Approx 45k-50k Miles
~ P28 ECU
~ *Solid* Transmission (No Grinds, No Pop-Outs, No Nonsense)
~ *New Clutch Kit (Exedy OEM Pressure Plate)
~ *New Flywheel
~ 5w30 Full Synthetic Oil
~ Honda MTF
~ *New OEM Timing Belt
~ *New OEM Water Pump
~ *New OEM Fuel Filter
~ *New NGK Spark Plugs
~ *New NGK Spark Plg Wires
~ *New Coolant Flush
~ *New OEM Thermostat
~ *New OEM Air Filter
~ Newer Battery
~ *New OEM Oil Pan Gasket
~ *New OEM IAT Sensor
~ *New OEM PCV
~ *Rear Main Seal
~ *Front Main Seal
~ Exhaust Manifold Shield Painted and Fastened With SS Hardware
~ *New OEM Cap
~ *New OEM Rotor
~ *New Valve Cover Gasket
~ *New OEM Fuse Box Lid
~ *New OEM Radiator Cap
~ *New Hardrace Engine Torque Mounts
~ *New OEM Cam Seal
~ *New OEM Distributor O-Ring
~ *New OEM Alternator Belt (Included, Not Installed)
~ *New OEM A/C Compressor Belt (Included, Not Installed)
~ *New OEM Transmission Axle Seals
~ *New OEM 1992-1995 Civic Si Axle-Back Muffler
~ *New OEM Oil Filter
Wheel/ Brakes: *= Parts With Less Than 4k Miles
~ Make/ Model- Kosei K1
~ Rim Size- 15x7
~ Lug Pattern- 4x114
~ Offset- +38
~ Hardware- Gorilla Polished Lugnuts With Key
~ New Kosei Valve Stems
~ 1996-97 Integra Type R Brake Conversion Purchased From JDM Orlando
~ *New OEM Front Wheels Bearings
~ *New Russell Stainless Steel Brake Lines On All Four Corners
~ *New Stoptech Carbon Brake Pads On All Four Corners
~ *New Brake Rotors On Rear (Fastbrakes.com)
~ Acura Integra 1" Master Cylinder
~ Acura Integra 40/40 Proporioning Valve
~ Acura Integra Brake Booster
~ *New OEM Master Cylinder Seal
~ *New OEM Brake Booster Gasket
Tire Information:
~ Front/ Rear Tires- 195/50/15 Triangle Tires With Approx. 60% Remaining
~ Alignment Complete At Pep-Boys on 6/02/2013
Suspension: *= Parts With Less Than 4k Miles
~ *New Hardrace Rear Trailing Arm Bushings
~ New Hardrace Front Lower Control Arm Bushings
~ Progress Technology CSII Coilover Suspension (Less than 10k Miles)
~ *AMR Extended Tophats on Front Shocks
~ Progress Technology Adjustable Upper Ball Joints (Front)
~ Newer drivers side and passenger side tie-rods
Price: PENDING
History: Im The Second (According to Carfax) since approx. 145k miles. I have enjoyed having the car and it has been beyond reliable and fun. The car is accident free, but was the victim of theft in March of 2011. It was recovered and rebuilt by me and the title remains clean (does not even show up on Carfax). The chassis currently has approx. 216k miles, but the engine will run with regular maintenance for 10+ years. Some of the exterior damage has already been mentioned, but the car does have significant sunfade on the roof, hood, and front/ rear bumpers. Additionally there is about an 8-10" crack in the rear bumper. I have a brand new OEM (discontinued) rear bumper still in the package that can be included for extra.
Call/Text
Russell: (407) 233- 9 Six Two Three
Pics (Click Image For High-Res):
(License Plate Frame and Subframe Brace Not Included)
(Shift **** anf Shift Lever Extender Not Included)
Old Jun 30, 2013 | 06:16 AM
Default Re: FS: 1995 Honda Civic DX Hatchback | Progress Tech. | SOHC VTEC | JDM | ITR |
No trades
Old Jun 30, 2013 | 10:36 AM
MaXtEr's Avatar
bump for a nice hatch!!!!
Old Jul 1, 2013 | 05:41 PM
Thanks, boss!
Old Jul 1, 2013 | 08:00 PM
KdiZzLe's Avatar
jizzed in my pants
Old Jul 2, 2013 | 08:36 AM
Originally Posted by KdiZzLe
jizzed in my pants
Nahh...
It's not that nice.
Old Jul 5, 2013 | 12:58 PM
Sale pending.
Old Jul 6, 2013 | 12:03 PM
flcivichb95's Avatar
Good luck !!
Old Jul 7, 2013 | 02:07 PM
DC4PB's Avatar
Nice and solid looking car.
Bump4u
ThaiRacer
Sep 1, 2013 01:54 PM
ThaiRacer
Aug 24, 2013 05:29 PM
RussLaviolette
Jul 5, 2013 12:55 PM
KRAP DIVAD
Northwest (Sales)
27
Jan 31, 2009 02:25 PM
civicsir.com
41
Nov 7, 2003 10:14 AM
