OH 1992-1995 B Series AC compatible Home Made Turbo Kit
Old Jun 28, 2013 | 02:15 PM
CRXB5's Avatar
Default OH 1992-1995 B Series AC compatible Home Made Turbo Kit
Selling my Home made turbo Kit.
Was on a 1995 Del sol b16a3 for 50K miles at 7 PSI. No problems, may have burned a tad of oil when let off throttle under boost but only burned about a half quart every 2.5 k. Street tuned on chrome. Can provide BIN file is desired.
Nissan Super 60 Cold side compressor and Mercedes diesel .48 AR hot side.
Internally wastegated at 7 PSI. Turbo is both Coolant and oil cooled.
Diesel Mitsubishi Intercoller, very efficient.
Home made IC PIPING and Air intake Tube with mounting bracket.
Mostly everythings included missing a few hose clamps but everything can be found at lowes thats missing.
Downpipe is fairly restrictive but clears AC compressor, no leaks. Log manifold is high quality steel and is also home made. Will have to notch the block a little for clearance Issues.
Ran 14.7 at 7psi on stock wheels and suspension. This thing can make 14-15 PSI and prolly hold it til 8 k if you have upgraded map sensor.
ASKING $200 FIRM NO TYPO. Need gone . Worst I can say is no.
PM me if interested. REALLY DONT WANT TO SHIP. Located in Northeast Ohio
I also have Correct Flange if buyer was willing to convert to external wastegate and weld a larger downpipe on. The samco Sport valve in picture will not be included a RFL knock off will be.
Heres a vid at 7 PSI (medium pulls)
http://www.youtube.com/watch?v=3DYnp...ature=youtu.be
want2na
Feb 14, 2012 01:58 PM
ITR.#1446
Mar 7, 2009 06:42 PM
import810
Oct 23, 2005 09:01 AM
t616
Sep 2, 2002 11:35 AM
