Another Head gasket..Need opinion
Old Jun 28, 2013 | 01:35 PM
skezix's Avatar
Default Another Head gasket..Need opinion
Hey all.. recentl did a head gasket on the youths 96 accord.. apparently it was cheap, or I did something wrong as it blew a few miles in.. Against popular belief that i should get rid of the car due to pure frustration I went ahead and pulled her back apart..
New head bolts, felpro gasket.. everything is clean, cleaned out bolt holes etc.. lubed bolts and heads/washers.. done enough HG's to be very tired of them in my life..
For the life of me I cannot get this thing to torque down without a squeek friction from a couple bolts.. I had it happen on "one" bolt on the previous gasket thus was my thought of why it failed.. now I have 3 that will not shut up..
Just concerned about leaving it like this as I feel I will be in for another head gasket once again..
I do not want to "lube" up to much as I do not need my bolt holes causing any suction or to filled with lube causing issues with torque..
Suggestions? want it out of the shop today! hehhe
Old Jun 28, 2013 | 10:41 PM
holmesnmanny's Avatar
Default Re: Another Head gasket..Need opinion
My guess is that your block is warped. My advice...get a used jdm engine and quit playing with that one.
Old Jun 29, 2013 | 10:02 PM
Hidenplanvew's Avatar
Or USDM... Might save a few bucks
Old Jun 29, 2013 | 11:13 PM
Orangevirus1's Avatar
I'd agree sounds like the engine is french toast.
Old Jun 30, 2013 | 06:19 PM
nus_dogg's Avatar
I had one bolt squeek on me, but left it after I backed it out and re-torque, same result. Everything was fine. It was on a D16Y8 Civic.
Almarazjose
Jun 4, 2019 08:07 PM
94 Civic Si
Engine Machining & Assembly
23
Apr 23, 2017 07:15 PM
99thwondah
Aug 28, 2016 02:31 PM
germ49
Jan 21, 2013 05:34 AM
metalmulisha87
Jun 29, 2010 10:43 AM
