2001 shifting issues
I dont have any check engine lights or the d4 light but my car is changing gear kind of rough.... As i drive down the street with the gas pressed the car will go up in rmps to around where it should shift and then go past it and when it changes gear it jerks not alot but enough that it has me worried where should i start fluid flush,a/b solenoids
I have a similar problem, My D4 is blinking, when shifted back to N and back to D4 gives a hard jerk... My car was flooded in a recent heavy rain... Water came inside the cabin... its 4 Cyl one... anyone troubleshooted such?
I took my car to the local autoshop who scans the codes...
Following are the results...
Could some one help me troubleshoot these?
P0700 Automatic Transmission Control System
P1705 Short in Transmission Range Switch Circuit (More than one range position is on at the same time)
P1706 Open in Transmission Range Switch Circuit
I suspect my car is not shifting more than 2 gears...
Muintir
Oct 25, 2016 08:42 PM
failcookie
Aug 2, 2016 09:50 PM
CRISIS
Aug 14, 2009 02:39 PM
