Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
01 Odyssey 6mt conversion
Old Jun 28, 2013 | 11:43 AM
MTRL-1 DAD's Avatar
Default 01 Odyssey 6mt conversion
Hello all, I am a new member here specifically joined up to get as much help as possible with my transmission swap.
I am the owner of a 2001 Honda Odyssey and my second AT just took a dump.
I refuse to invest any time, money, and energy into replacing/rebuilding the stock AT.
So with that being said I found an 08 Acura TL-S 6MT locally for 600 bucks that I will be swapping in. I need some help from knowledgeable members who have done this conversion.
I live in Ca so in the future I will be also swapping in the j32a2 from a donor car (with all necessary parts to make this swap pass state ref inspection).
I need help figuring out what axles will work if any or if I need to have custom ones made?
I think everything else should be easy for me.
Can anybody help or point me in the right direction?
I will also have a detailed write up for any future members who are interested in this transformation as well.
Old Jun 28, 2013 | 11:15 PM
MTRL-1 DAD's Avatar
Default Re: 01 Odyssey 6mt conversion
I figured I would try using my stock axles mated with the TL inners and go from there.
I'll also be using a DC clutch pedal with master cylinder and remote reservoir assembly.
Maybe a Hybrid Racing shifter box with RSX shift linkages.
That's pretty much the gist of it. The rest is pretty much wiring.
ek_Tart
Suspension & Brakes
Oct 4, 2007 11:16 PM
eJ6DM
May 16, 2006 07:09 PM
spoonfed95
Mar 14, 2003 02:55 PM
1quickvr4
Oct 29, 2002 09:19 PM
