del sol - starts briefly and then turns off
Old Jun 28, 2013 | 05:37 AM
lazycamper's Avatar
Default del sol - starts briefly and then turns off
I have a 95 Del sol with a d16y8 engine (p28 ecu). Problem is that every blue moon the engine will start goofing up. It will turn over but wont stay on. Then later it will start up as if nothing happen. Its been doing this for about 2 weeks now. I have gotten new spark plugs. Its getting a nice white spark, engine is getting fuel, all fuses are good. I've check on honda-tech and googled my problem. I don't think the main relay is a problem. It has the chipped key which I'm not too familiar with since my old coupe didn't have it. Any ideas?
Video of what its doing:
https://www.facebook.com/video/video...02338590&saved
The 3rd time I'm holding the key in the cranking position.
https://www.facebook.com/video/video...24701631&saved
Old Jun 28, 2013 | 05:57 AM
instrument's Avatar
Default Re: del sol engine problem
Sounds like a fuel pump to me.
Old Jun 28, 2013 | 06:14 AM
S2BumpsticksGSR's Avatar
Last fuel filter change?
Old Jun 28, 2013 | 06:53 AM
B_Swapped93's Avatar
have you checked fuel pressure
Old Jun 28, 2013 | 08:03 AM
lazycamper's Avatar
I will see if the store has one in stock this weekend.
I have not, I know fuel is getting to the filter and fuel rail. As to the actual PSI, I have no clue at the moment.
Old Jun 28, 2013 | 08:45 AM
Former User's Avatar
CEL codes?
By the way, these^ tests yield no useful information unless done when the engine WON'T start.
Old Jun 28, 2013 | 08:48 AM
are the injectors getting signal (12V) ?
Old Jun 28, 2013 | 09:08 AM
lazycamper's Avatar
Originally Posted by RonJ@HT
CEL codes?
That's the thing that boggles my mind the most. There's no CEL codes even when I jump the connector.
Old Jun 28, 2013 | 11:27 AM
Does the CEL work?
Reply to this^
Old Jun 28, 2013 | 10:57 PM
lazycamper's Avatar
CEL codes?
The spark test was done when the engine was not working right.
Old Jun 28, 2013 | 11:41 PM
Ryan Lwin's Avatar
How did you check if engine is getting fuel? Did you just listen to fuel pump priming? That doesn't necessarily mean it's getting fuel. Clogged filter and dead injectors will make engine lack fuel also.
This looks like engine is out of gas. So, you must not be getting fuel into the combustion chambers. Take the top of the filter and turn the key to ON to see if the fuel comes out. Make sure to have towers around it so that you don't get it all over the place.
Old Jun 28, 2013 | 11:48 PM
bsm760's Avatar
I'm haveing the same issues wth my wife civic, I'm new here and I've been hackin at the for 2days any will b greatly appreciated
Old Jun 29, 2013 | 04:25 AM
lazycamper's Avatar
Every time I take the spark plugs out they have wet fuel on them.
Old Jun 29, 2013 | 04:40 AM
grumblemarc's Avatar
The Grumpiest
Someone asked you WAAAAY back if the CEL actually worked. What color is the spark?
Old Jun 29, 2013 | 04:43 AM
lazycamper's Avatar
The light build in the instrument cluster does in fact work, spark is bright white.
Old Jun 29, 2013 | 04:49 AM
The Grumpiest
Ignition switch faulty? Would explain the no lights thing.
Old Jun 29, 2013 | 04:53 AM
lazycamper's Avatar
A friend of mine that has more experience in Hondas told me that he thinks it could be the ignition switch or the ECU. How would I be able to determine of the ignition switch is faulty?
Old Jun 29, 2013 | 05:53 AM
Lizardslap's Avatar
here this thread
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/how-do-you-test-ignition-switch-ef-2922526/
that also had this link
http://techauto.awardspace.com/ignitionswitch.html
Old Jun 29, 2013 | 07:49 AM
lazycamper's Avatar
Originally Posted by Lizardslap
Thanks for the links! Currently reading the material to preform the tests.
Old Jun 29, 2013 | 08:05 AM
Bad ignition switch is a very good fit with the problem.
...but what is this chip you speak of? Immobilizer? Seems like it could also be the problem.
Old Jun 29, 2013 | 10:17 AM
lazycamper's Avatar
Default Re: del sol - starts briefly and then turns off
Basic troubleshoot: If the car stalls and after starting refuses to remain idling:
Turn the ignition OFF and restart the car. Once started slightly release the key from the start position (III.) Don't let the key fall back into run position (II) but don't let the starter continue to run. Most often, the car should not stall. If this is the case then the electrical switch is most likely bad.
Tried this and this seems to be it.
Old Jun 29, 2013 | 12:12 PM
lazycamper's Avatar
Filter has been changed as of today.
Old Jun 29, 2013 | 01:01 PM
Ryan Lwin's Avatar
I guess you need a new switch.
Old Jun 29, 2013 | 11:56 PM
lazycamper's Avatar
Used a DMM tool to test the contacts on the ignition system for voltage. The actual ignition wire (Blk/Ylw) gets no power at all. Will be uploading a video of my findings shortly.
Last night I also took the switch apart and inspected the contacts, there seems to be solder on the contact that the mentioned wired is connected to. All contact points have a bronze like color to them, contact ring seems to be in "Good" condition according to the link
Lizardslap provided.
Old Jun 30, 2013 | 12:27 AM
lazycamper's Avatar
https://www.facebook.com/video/video...ideo_processed
