CV boots for ZC axles? (ZC L3 tranny)
From what I've read, the integra equal-length axles are different than the ZC equal-length axles, but what about the boots? Is there an american version honda vehicle I could order new boots for that would work on my ZC axles?
ZC? Dohc ?
The Si axles will work with the L3 Tranny provided you have the SI hubs or DA integra hubs. Ordering new boots and replacing them is a pita when you could just order new or reman axles and install them in a far less amount of time.
What I have is a sohc ZC with the ZC L3 tranny... meaning it has equal-length axles and an intermediate shaft.
Si, DX, HF... none of those axles will work.
I'm trying to find boots that will work for my axles because it seems replacing these axles themselves would be neither cheap nor easy to find. (The integra equal-length axles will not work either.)
did you already try the 90-93 integra axles, years ago when i did this swap on my first ed we used 90 integra axles, knocked a rubber ring off of each axle on the hub side, then took the dust ring out of the knuckle and done drove for a year with me no problems. thezcr.com has a bunch of info for zc stuff look over there for more info
