Honda CR-V & Element 2WD & 4WD Element & CR-V
2002 CRV Air Conditioning
Old Jun 27, 2013 | 04:59 AM
DG2klx's Avatar
Default 2002 CRV Air Conditioning
I have a 2002 CRV and the AC is not blowing cold. I hooked up a set of gages, I have about 80 PSI on both low and high side of system. With the engine on, AC on, fan blowing, the pressures do not change.
This would suggest the compressor is not kicking on. Does anyone have a wiring diagram of the AC system?
Old Jun 27, 2013 | 09:20 AM
DG2klx's Avatar
Default Re: 2002 CRV Air Conditioning
Little more information. The condensor fans kick on as soon as I hit the AC switch on. I tried pulling the relay and jumping it, compressor still did not kick on. This seems to indicate I have a bad compressor clutch. Sound slike alot of fun changing out a compressor.
xxjokoxx
Aug 23, 2010 12:51 AM
lakerschamp2000
19
Apr 24, 2009 12:37 PM
Civic Racer X 7
Aug 23, 2007 08:42 AM
Civic Racer X 7
Aug 8, 2007 05:15 PM
vietnogi
May 24, 2005 08:01 AM
