1993 Accord Leaking
Old Jun 26, 2013 | 06:50 PM
thequesogrande's Avatar
Default 1993 Accord Leaking
Two days ago, my 93 Accord started leaking a clear, odorless fluid (it looked very much like water). It stopped sometime between last night and this morning. The leak was a slow drip from just behind the front right wheel well. Any ideas on what it could be and what I should do about it?
Thanks.
Old Jun 26, 2013 | 07:52 PM
1990 CB7's Avatar
Default Re: 1993 Accord Leaking
It could be the A/C Evaporator.
A/C evaporators drip water created by condensation when the A/C is being used. The housing that holds it under the dash collects this condensation and funnels it through a drain hose through the firewall into the engine compartment, where it drips under the car. All cars do this.
If this happens when you ARE NOT using A/C, I honestly have no clue.
Old Jun 26, 2013 | 09:56 PM
holmesnmanny's Avatar
Also, even if you don't have the ac on...assuming you have ac on your car...if you put the defroster on it will turn the ac on automatically.
cooxen77
Jun 24, 2019 12:30 PM
vaguy
Mar 12, 2018 07:41 PM
Fixit-13
Honda Accord (2013 - 2015)
Oct 19, 2017 04:38 AM
dave f
Jul 23, 2006 04:32 AM
