ASR Rear Sway Bar Problem - After their bracket fix
Old Jun 26, 2013 | 10:02 AM
atc5's Avatar
Default ASR Rear Sway Bar Problem - After their bracket fix
Anyone else encounter this?
Is anyone from ASR on this forum that can address?
Old Jun 26, 2013 | 11:21 AM
10cjennings's Avatar
Default Re: ASR Rear Sway Bar Problem - After their bracket fix
I think you put the bushing in the wrong way.
That lip on the outside edge should be on the inside.
Or did the bushing have the same lip on both sides and it tore?
Old Jun 26, 2013 | 11:50 AM
94rs-turbo's Avatar
looks like you installed incorrectly, flip it around so bushing
and arrow point l-->l l<--l
Old Jun 26, 2013 | 12:10 PM
Calif_Kid's Avatar
They're correct - you've got the rubber bushing and the metal bracket both on incorrectly. The larger diameter part of the rubber bushing should contact the metal washer that is welded on the sway bar, and the arrow on the metal bracket should face toward that metal washer. The metal bracket has a recess for the rubber bushing. The kit probably came with one page of install info. - Jim
Old Jun 26, 2013 | 01:28 PM
atc5's Avatar
boom!
fixing now!
thanks everyone including ASR for the quick reply by email!
rovafa2002
Feb 22, 2014 07:57 AM
rickscrx
10
Dec 27, 2011 10:53 PM
shahriar35
Nov 16, 2011 05:14 AM
92_prelude
Apr 16, 2007 05:17 PM
