Jdm d16zc obd1 to obdo
Old Jun 25, 2013 | 07:20 PM
Hondaman45628's Avatar
Default Jdm d16zc obd1 to obdo
I'm new on here and am in need of some help I got a 91 crx si and wanting to put the d16zc sohc in it but its obd1 how do I convert it to obdo so I can run my si harness and the pm6 ecu any help would be great thanks.
Old Jun 25, 2013 | 08:44 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Jdm d16zc obd1 to obdo
PM6 ECU is a bad way to do this.
You will need to buy a vtec controller to get vtec to work.
Then you will need some way to bump up your fuel map during vtec.
A lot of guess work and finger crossed and it will still never be quite right.
Get the proper P28 and convert to OBD1.
OBD1 jumper harnesses aren't very expensive and will have your Z6 running like it was meant to.
Old Jun 25, 2013 | 08:55 PM
It's the jdm d16zc not the z6 it's non vtech motor but its the obd1 motor and just want to make obdo so it will just plug right into my crx si harness
Old Jun 25, 2013 | 09:20 PM
4drEF's Avatar
Keyboard Humorist
Sorry about that!
Most people call them ZC - all together with D16 had my eyes seeing D16z6.
Does your stock distributor bolt right up to that motor?
If so, then swap out the distributors and the intake manifolds and extend the wires for the cooling fan switch from the back of the motor to the thermostat housing.
Old Jun 26, 2013 | 02:43 AM
OK cool thanks man
Old Aug 12, 2013 | 07:41 PM
danielolaguez92's Avatar
Originally Posted by Hondaman45628
OK cool thanks man
Wait does your stock distributer bolt right up?
BMFstl
Oct 24, 2010 08:57 PM
sublimeh215
Jan 29, 2010 06:41 AM
superhatchbackbros
Dec 13, 2007 10:30 AM
Si2See
13
May 19, 2005 11:13 PM
usdm_ED7
11
Jun 20, 2003 08:01 AM
