help please ef sedan pedale assembly removal
Old Jun 24, 2013 | 02:06 PM
kris9's Avatar
Default 1
Old Jun 24, 2013 | 02:14 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: help please ef sedan pedale assembly removal
There should be 6 nuts holding it to the firewall and one that is hidden facing up, between the steering column and steering frame (I don't know the direct terminology there). Anyways, drop the steering column and you'll see the hidden one. Also, use the search function and it might help. I can't tell if the pics are gone because my work blocks certain sites but if you put in a little effort searching here or on google you'll come across the pics (I just searched on here and got a few hits).
Old Jun 24, 2013 | 02:19 PM
Charlie Moua's Avatar
what is the split bar?
Old Jun 24, 2013 | 02:20 PM
24TEN's Avatar
PHANTOM MENACE
^I think he's referring to the bar that the pedal pivots on. Seems to be typical to snap/break on this chassis.
Old Jun 24, 2013 | 02:41 PM
24TEN's Avatar
PHANTOM MENACE
You've made it that far, I'm certain it's just that one last nut that's right above the steering column. I experienced the same thing years ago and I'll never forget the hidden nut.
You wont' have to remove the switch but you will need to unplug it.
Old Jun 24, 2013 | 03:29 PM
4drEF's Avatar
Keyboard Humorist
Also have to disconnect the brake pedal from the booster push rod if you haven't.
Old Jun 24, 2013 | 09:33 PM
4drEF's Avatar
Keyboard Humorist
Weld AND reinforce!
If you get a new used one, you face the same problem happening again.
Old Jun 25, 2013 | 07:36 AM
claws's Avatar
I literally just did this yesterday in my '91 DX. Remove the driver's seat first, it's held on with only 4 bolts and you'll be glad to have the extra work space. Disconnect the wires from the fuse panel, drop it out of the way. Drop the steering column to the floor as well, it's held up by four bolts and two nuts. Pull out the two ducts that run above the steering column. The section that's in your way isn't held by any fasteners. Disconnect the throttle, brake, and clutch pedals (the brake pedal is the only one fastened, the clutch and throttle cables just hang on the pedals). All the bolts should be clear as day at that point. There are six that hold the unit to the firewall, plus one that holds it above the brake pedal.
I used various combinations of a 12mm deep socket, 12mm regular socket, 3" and 6" extensions. The whole job took me less than 5 hours, and that's only because I got hung up trying to get the ducting out. If I had to do it again I could probably do it in less than half the time. I'm not going to reinstall the ducting, but I assume you would have to remove the dash to do so.
I'm going to post some pictures in my thread in a few hours. If you're still having trouble check back and they may help.
prelude1897
Apr 19, 2010 12:39 PM
91Hatcher
23
Dec 22, 2008 12:39 PM
freeeked
Jul 10, 2004 04:41 PM
travis
Dec 27, 2001 12:56 PM
Honda318dx
19
Aug 26, 2001 01:15 PM
