IL FS/FT: CLEAN 2007 Subaru WRX
Old Jun 24, 2013 | 09:48 AM
Battle Monkey's Avatar
Default FS: CLEAN 2007 Subaru WRX
**PRICE DROP, NO TRADES**
Asking $16,000 as the car sits in the pictures. You will also get the OEM wheels, along with the RPF1s
I would consider trade for an AP1 S2000 + cash.
2007 Subaru WRX
77,XXX miles
Clean Title
Original Owner
I'm posting for sale because I'd like to get started with a new project. The car is SUPER clean, everything done has been with function at the forefront. It's currently making 303/296, conservatively tuned by Mitch at AMS (now Tuner at Cobb) on their Mustang dyno (Cobb AP V2). Only troubles with the car as it sits, is the 4th gear synchro is a little bit notchy in the cold weather, and the rear right wheel has some very slight toe-in (probably the trailing arm bushing a little worn or rear subframe alignment)
I'd ideally like to find someone that will appreciate all that has gone into this car. Otherwise, I will more than likely part it out and sell in the coming months.
More details below. Feel free to get in touch with me if you have additional questions. PM me for my email or cell #.
Engine
Built EJ255 by Turn In Concepts
Cobb SF2 Intake
FP 68HTA
TurboXS Stealthback Exhaust
44mm Tial External Wastegate (fabricated OEM up pipe)
Grimmspeed 3-port EBCS
Process West TMIC and Splitter
Perrin Intake Heat Shield
Perrin Inlet and post-MAF tube
Deatschwerks 750cc Injectors
CP Racing Forged Pistons (coated by Swaintech)
ACL Main/Rod Bearings
ARP Head Studs
Covert Performance Oil Pickup
S2 Air/Oil Separator
Iridium IX Spark Plugs
Air Pump Delete
Gates AC and PS Belts
TGV Deletes
AP V2 Tuned by Mitch at AMS (303whp/296wtq, very conservative tune)
Suspension
Perrin 22mm RSB
Kartboy Rear Endlinks
Epic Engineering Springs
MSI Direct Steering Kit
Whiteline Roll Center Adjusters
MSI Rear Lateral Links
Front Camber Bolts
Kartboy Rear Subframe Lockdown Bolts
Alignment (-2.1 camber f, slight positive caster, 0 toe)
Bushings
Kartboy Crossmember
Kartboy Shifter Linkage
Perrin Rear Shift
Kartboy Rear Diff Outrigger
TiC Rear Diff Main Brace
TiC Rear Lateral Link
TiC Rear Trailing Arm
Drivetrain
Clutch Master FX300
Fidanza Lightweight Flywheel
SPT Short Shifter
Torque Solution Engine Mounts
Wheels and Brakes
17x8 Enkei RPF-1
245/40/17 Hankook R-S3s
Stoptech Street Performance Pads (F+R)
Amsoil Series 600 Brake Fluid
DBA 4000 T3 Front Rotors
Centric Premium Rear Rotors
TIC MBC Brace
Interior / Exterior
Recaro DC-5 Seats (custom fabricated)
Crow Enterprizes 5-pt Harness
20% Tinted windows
2005 taillights
Wideband AFR and Boost Gauges
STI Rear Diffuser
Wingless trunk
Old Jun 25, 2013 | 11:18 AM
BSERIEuS's Avatar
Default Re: FS/FT: CLEAN 2007 Subaru WRX
Check your PM please
Old Jun 25, 2013 | 01:43 PM
t.schultz's Avatar
How much on top? I have a AP1
Old Jun 25, 2013 | 01:49 PM
Shoot me a pm with some pictures and whatnot.
Old Jul 4, 2013 | 07:32 AM
Price dropped to $16k firm
Comes with everything on the car, plus the OEM wheels, along with any spare parts I have laying around.
Old Jul 4, 2013 | 12:27 PM
Honda-Newb's Avatar
very nice car!
gc8andy
Sep 24, 2010 10:51 AM
DIYKITS@BB4lude
Feb 22, 2009 08:53 PM
Chicago_Type_R
May 4, 2008 09:02 PM
Chicago_Type_R
Apr 3, 2008 10:37 PM
