B16 Cam Cap Bolt replacement?
Old Jun 23, 2013 | 04:43 PM
F22Master's Avatar
Default B16 Cam Cap Bolt replacement?
Well im just about done with a head gasket job on my JDM B16A and of course, something had to go wrong... And of course it was the last bolt I had to torque down... It was the cam cap bolt in the very top left corner of the head, by the distributor. It snapped clean in half with a nice 'ping'. Yes, I was using a torque wrench, it was set to 195 in/lb (16 ft/lb).
After removing all the bolts and the cam cap rail I (luckily) managed to get the bolt out by drilling and using a left-hand-twist bolt remover. I then inspected the rest of the bolts... and f***ing s***, almost all of them have MASSIVE amounts of stretch distortion... Then I took off the exhaust cam cap rail. About half of them showed signs of stretching. I guess someone had overtorqued these before...
So, what should I do for replacing all of them?
I have read about people having problems even with brand new oem bolts...
I was thinking of just getting some 12.9 M8x1.25x50 Socket Head Cap Screws and use some properly sized washers. Any good reason not too?
Old Jun 23, 2013 | 05:01 PM
Freemananana's Avatar
Default Re: B16 Cam Cap Bolt replacement?
Just use ARP Head studs? Is that what you are replacing? I have head of people snapping these (OEM) head studs even at the correct torque. I can't explain it. But I don' think I'd go with anything less than the best.
I may be thinking of the wrong thing. Correct me if I am.
Old Jun 23, 2013 | 05:26 PM
F22Master's Avatar
Sorry, I guess I wasnt clear. I broke one of the cam cap hold down bolts. NOT a headbolt (Yes, im using ARP).
Old Jun 23, 2013 | 05:31 PM
Oh! My bad. Haha. Okay. I see what you're talking about. I can understand that from the original post now. I just got on head studs and stayed there in my mind. I'm not really sure. Seems unusual to me. Never replaced the cap bolts.
Old Jun 25, 2013 | 10:40 AM
F22Master's Avatar
Anybody?
I went to my local Merit Fastener yesterday and all they had in M8x1.25 50mm long was grade 8.8. I didnt get them because im just not sure if 8.8 would be strong enough...
Old Jun 26, 2013 | 04:00 AM
BiGZ's Avatar
Some yahoo had done same to cpl of bolts on my b16a "spare" head (bought 2nd already built head + installed it + 2 bolts were stretched to point of narrowing in middle also,ugh!) Luckily had 2nd head w/ hardware to replace em. Pretty certain that grade 8.8 will suffice. (grade 10'd be betta,but just don't over torque teh 8.8'z...)
Old Jun 26, 2013 | 04:46 AM
zrickety's Avatar
I would just get all those cam cap bolts from honda. I've never heard of problems with those, but someone could have over-torqued them. Just replace them all and hope none of the holes strip out. I bought a car before that needed a bunch of heli-coils thanks to some gorilla over tightening everything.
Old Jun 26, 2013 | 04:49 AM
TheMightySi's Avatar
Buy them at honda man its worth it
Old Jun 26, 2013 | 10:23 AM
F22Master's Avatar
I have read several reports of brand new cam cap bolts from honda breaking. Im not taking thrat chance. I have ordered 2 diffeent kinds of bolts from mcmaster carr. Class 12.9 Socket Head Cap Screw, and 10.9 Black Finish Steel Hex Head Cap Screw. Both packs of 25. They were only $7 for each pack. I also picked up some M8 washers, since neither of the bolts have flanged heads. I'm still not sure which ones im going to use...
HypL
Apr 6, 2020 10:10 AM
Smash03
Feb 10, 2017 04:39 PM
91Honda_gsr
Engine Machining & Assembly
10
Apr 25, 2016 09:45 PM
EkChuck
Dec 1, 2012 07:50 AM
JDMlyfestyle
Nov 20, 2004 12:29 PM
