Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
06 Honda Civic gets stuck in gear (automatic)
Old Jun 23, 2013 | 12:01 PM
Nathan Allen's Avatar
Default 06 Honda Civic gets stuck in gear (automatic)
What should I trouble shoot to find out why my 06 Honda Civic will not always shift into park. Sometimes, I have to leave it in neutral and pull the E-brake and leave the key in. There is a lever next to the automatic gear shift, but it does not help any. Please advise.
Last edited by Nathan Allen; Jun 24, 2013 at 12:10 PM. Reason: Updated information
Old Jul 22, 2013 | 09:05 PM
go-part's Avatar
Default Re: 06 Honda Civic gets stuck in gear (automatic)
Is there enough transmission fluid?
Also you may want to look into replacing the shift cable.
Old Jul 23, 2013 | 09:48 AM
av911's Avatar
Don't you need to press on the brakes to put it in to PARK? I remember I couldn't get it OUT of PARK and I had to replace the fuse. If your brake lights or horn doesn't work, check the fuse.
StuckShiftless
May 25, 2017 09:57 PM
Shannon Sampson
Dec 4, 2012 09:19 AM
hybridcivicowne
Aug 26, 2009 07:09 PM
