B18cR high idle/no vtec
Old Jun 23, 2013 | 06:23 AM
Coopa B18c5's Avatar
Default B18cR high idle/no vtec
Hey guys! first off just want to say that my car is a 1998 gsr WITH a jdm ITR motor. I'v been having this problem for a while now and iv posted it up on the regular integra forum, but that has got me absolutely nowhere... PLEASE HELP : (
Please delete if breaking rules --
My question.
I have a 98 gsr with a jdm itr and p73 ecu. Intermittently the cars idle will go up AND vtec wont work. It goes back into its "warm up" procedure just like i started her from being cold/sitting awhile. if i turn her off and back on. idle drops back to normal and vtec works properly. searched EVERYWHERE and no one has this exact problem.
I'm pretty sure its a bad sensor but dont know which one..
been going on for 8 months and i can not take it anymore. I just replaced my ECT connector (it was cracked) and that didnt do anything. Just replaced the ECT sensor itself which again did NOT solve the problem..
So what sensors control it knowing when engine temp is warm enough to drop idle or what electrical systems aid in this so i can start narrowing down the problem? It also very weirdly enough seems to happen more at night time. from south jersey so its mid 80s during day and mid 60s at night. dont know if the temperature plays a part in this or not.
So any insight on this matter will greatly be appreciated!
* Put original cluster back on (didnt do anything)
* Cleaned IACV (no help)
* Engine oil is at perfect level
* Grounds are perfect. even added 2 more.
* Replaced ECT connector
* Replaced ECT sensor
Old Jun 23, 2013 | 07:33 AM
sicones's Avatar
Default Re: B18cR high idle/no vtec
Is the check engine light on?
Old Jun 23, 2013 | 09:18 AM
yes sir. i just pulled them using the jumper
I got 6 codes..
1. Coolant temperature
2. Throttle angle
3. No 1 cylinder position
4. Vtec solenoid valve
5. Knock sensor
6. 02 sensor heater
Now would i have some of these codes because it has a swapped motor in a gsr shell? i can see #6 because i have a straight pipe on with no 02 sensor.
Why would i have a coolant temperature light? i just replaced (auto zone part) it was on a sunday and wanted to get it done that day.
Old Jun 23, 2013 | 11:17 AM
sicones's Avatar
Pull the battery to clear the codes. Start the car back up, let it warm up and then check back here with what codes are left.
Old Jun 23, 2013 | 11:22 AM
I just picked up a new TPS that im going to throw on and then ill reset the ecu. ill let you know
THANKS
Old Jun 24, 2013 | 12:24 AM
I have a knock sensor in, but its not hooked up to anything.. and i dont see an extra connector anywhere.. do you know why that would be?
Old Jun 24, 2013 | 04:56 AM
sicones's Avatar
What engine harness are you using?
Old Jun 25, 2013 | 08:41 PM
Rdriver's Avatar
When you changed the sensor did you inspect the plug for corrosion?
Acc3l3ratoR
Jul 31, 2018 05:50 PM
Azad_R
Oct 2, 2013 07:54 AM
Coopa B18c5
Jun 9, 2013 12:26 AM
96CivicBoostCoupe
Jul 22, 2005 12:26 PM
Mr_CRX
Sep 29, 2004 12:01 PM
