Lighting HID/Xenon kits, Retrofits and Associated Topics
Turn Signal Blinker not working
Old Jun 23, 2013 | 12:13 AM
Acethriller's Avatar
Icon2 Turn Signal Blinker not working
The left front turn signal does not blink when the signals are on, when the hazards are on, or when I lock/unlock the doors. Though the parking light does turn on at night, which I believe is the same bulb as the turn signal blinkers.
What could be the issue here? what should I check?
Thanks in advance.
Old Jun 24, 2013 | 09:42 AM
Default Re: Turn Signal Blinker not working
No advice?
Old Jun 25, 2013 | 12:58 AM
Outrun's Avatar
I'm assuming it's a dual filament bulb like 1157 or 3496. If so, then one of the filaments may have burned out. Switch out the bulbs from the left front with the right front and see what happens.
Old Jun 25, 2013 | 05:14 AM
Ahh, I did not think about that, just assumed there was a problem when the parking light worked but signal didn't . Could very well be the issue. Will give it a try, Thanks a ton!
Old Jan 4, 2014 | 11:30 AM
TikkiTimBro's Avatar
Hey man, sorry to bump your thread but I have the same issue and replaced the bulb but still I have no blinker... Just my running lights at night.
Have any advice on how you fixed the problem?
Old Jan 4, 2014 | 11:39 AM
ferio-ichi3's Avatar
Ferio Wdm Edition
check to see if you have a break in the wiring. put a test light on the power wire and see if you are getting power.
Old Jan 4, 2014 | 07:58 PM
Unfortunately I have no idea how to go about fixing it as I sold my car a while ago with the issue unresolved, didn't have the chance to replace the bulb.
Hope yours gets resolved soon, good luck!
MDAMP2005
Oct 31, 2018 06:51 AM
Mister_1
Honda Civic (2006 - 2015)
Jun 5, 2018 05:36 PM
acura1masco
Acura TL, RL & ZDX
Jun 7, 2007 08:32 PM
mookie
Honda Motorcycles
Sep 7, 2006 03:17 PM
