JDM b16a obd0 to b18/b20 swap question
Old Jun 22, 2013 | 11:28 PM
JustEFit's Avatar
Default JDM b16a obd0 to b18/b20 swap question
later further down i want to do b18v or b20v, i was wondering if i switch motors for now then do b18v/b20v later, can i use the same wire harness, and ecu a b16a obd0 uses?
Old Jun 23, 2013 | 07:27 AM
F22Master's Avatar
Default Re: JDM b16a obd0 to b18/b20 swap question
Yes.
Old Jun 23, 2013 | 06:17 PM
JustEFit's Avatar
so its all good? just like that.
Old Jun 23, 2013 | 06:22 PM
F22Master's Avatar
As long as you keep the same distributor, then yes it's that easy. The other option is to convert to OBD-1. Then you would need a Distributor, 4-wire O2 sensor, OBD-1 ECU, and then convert the plugs to work with the new stuff.
Old Jun 23, 2013 | 06:25 PM
JustEFit's Avatar
k well i still have the same distributor, so im going to keep my distributor from my b16a so that i could have to get all that stuff.
xalents23
Northern California (Sales)
May 22, 2009 01:11 PM
thatEFboy
Jul 8, 2008 10:17 AM
IEATLINT
Jun 28, 2004 01:53 PM
EG6AAARRR!!!
Mar 7, 2004 03:55 PM
