b16 swapped 91 si wont start
Ok I just swapped a b16a into my 91 si and I just finnished putting it in and when I hooked up the battery and turned the key and the starter does nothing at all...I can here the relay under the dash clicking and the one under the hood clicking but the starter doesn't make a sound.I even tryed jumping the starter and nothing...the starter worked in the eg it came out of and the starter in the ef worked before I pulled the engine...someone tell me something
That site was really helpfull but I still cant figure it out...I had the starter tested and its fine..I tested the relay and its fine I even tried putting a direct ground from the starter to the body thinking it was a ground problem and I still have nothing some one please help lol im really getting anxious to drive this thing and work out the kinks but I cant get it running to do that
Did you check the battery? What is the voltage? Do you have another battery to try?
Put 12v directly to the main starter power hookup and to the solenoid prong. If it doesnt work either your starter doesnt work or your battery is dead.
Is the rubber bumper for the clutch start switch there and intact? Looks just like the rubber stop for the brake light switch but there is also one for the clutch start switch. I had one crumble and fall out and had me go crazy for a couple of hours trying to figure out why my starter wouldn't work until I saw the rubber pieces in the floorboard.
I have two batteries I tried them both and I used a jump box and still nothing..and I disconected the saftey switch on the clutch and looped it so I could use a remote starter switch.and the dizzy and cap and rotor are new cuz when I got it it had a missfire issue and I repkaced them but thats another storry......I know its gotta be a ground issue. How many grounds do I need cuz I have one off the valve cover and I put one from the starter to the boddy thinging it would help but still nothing.... do I need a tranny ground and maybe another?
im betting its the thermostat ground. have you tried keying on and running a hot wire to the starter signal wire?
starter only has two leads, 12vdc to the battery and signal wire from the ignition switch. the return is directly grounded via the starter chassis to the transmission housing... the transmission gets a separate ground the the car chassis... completing the circuit. you didn't ground the tranny....
2minute check... put your multimeter on diode check.... either lead onto any part of the transmission housing, the other lead to your starter chassis... you will hear a beep. now connect the lead to your starter chassis and the neg on your battery. 99% sure you won't hear anything... if so.... there is a bolt on top of transmission that should have a wire on it, that wire should be attached to the passenger side wheel well. under the or near the tranny mount.
Ya it was the ground on the thermostat Iit already one on there soo just for the hell of it a ran another one on top of it and it fired right up....so good call clay
thermo ground Is the harness main zero reference ground... the same ground your ecu grounds to. shouldn't have kept your starter from turning.... :/ good job getting done.
I really like how the hood with the eyelids built in look but I was just wondering if anyone new a company that makes or selks them or if I have to make it myself .....
baboonstyle
10
Nov 19, 2005 02:22 PM
sloboy_joe
Nov 12, 2004 12:48 PM
