A Rear Sway Bar that will clear 3" Kteller piping ??
Old Jun 22, 2013 | 03:34 PM
Vagitarian's Avatar
Default A Rear Sway Bar that will clear 3" Kteller piping ??
Hey guys, I am looking to upgrade the rear lower sway bar. My main concern is clearance of my 3" exhaust is there any large diameter bars that have better clearance in that area than others??
Would pics or measurements help at all?
Im looking for options on which bars would fit and which people would recomend. If it fits with stock piping is one thing, but the 3" take up alot of room and I would hate to have it not fit come install time.
Old Jun 22, 2013 | 03:39 PM
Vagitarian's Avatar
Default Re: A Rear Sway Bar that will clear 3" Kteller piping ??
I should probably mention the car is a 89 Crx si with factory rear sway bar and my exhaust clears that fine, so maybe there is a best style that is routed like stock?
I also have stock control arms
Old Jun 24, 2013 | 05:02 AM
Vagitarian's Avatar
bump, want to buy!
Old Jun 25, 2013 | 09:49 AM
Vagitarian's Avatar
nobody loves lower rear bars anymore?
Old Jun 25, 2013 | 10:45 AM
myefhasaname's Avatar
I had similar problems but not with as big as a pipe. I resolved it by using one mounting bracket from a da on the left and a civic is bracket on the right. Might have different mounting holes on the Rex vs civic but who knows might help.
Old Jun 25, 2013 | 04:14 PM
90_EX_Civic's Avatar
look up ST sway bar. mounts replace your tow hooks, and mounts up almost like the stock one.
Old Jun 25, 2013 | 11:50 PM
Vagitarian's Avatar
After researching I see alot of thread of people having interfrence with aftermarket exhaust with the ST
Old Jun 26, 2013 | 02:33 PM
only other route would be a asr plate/sway bar
Old Jun 27, 2013 | 12:33 AM
Vagitarian's Avatar
Only other option?
What makes the ASR combo clear my exhaust more than others
Old Jun 27, 2013 | 02:35 PM
only suggest it because of where it mounts, at your rear subframe. it should clear your exhaust pipe, but that's still subjective. because i don't know how much of a clearance you have with the pipe going over your control arm.
here's a pic, for reference.
**** mind taking a pic of the exhaust on your car, and how much clearance you have around the lca.
Old Jun 28, 2013 | 01:11 AM
Vagitarian's Avatar
Thats a nice setup but much more than I am looking to upgrade. I think it would be much simpler and more in my budget to find a bar that is routed and mounted like stock, just beefier, and hopefully including endlinks to attach to my stock control arms
Old Jun 28, 2013 | 06:00 AM
BLU CIVIC's Avatar
Track Advocate
friend of mine has a 3" Thermal exhaust with a ST 22mm rear sway bar. so you should have no problems with your kteller.
Old Jun 28, 2013 | 10:01 AM
KevinEF7's Avatar
Do most bars come with endlinks for stock control arms?
Old Jun 28, 2013 | 08:56 PM
Vagitarian's Avatar
ST bars aparently have bad exhaust clearance
Are any bars known for GOOD exhaust clearance? and take the stock path
Old Jul 1, 2013 | 09:35 PM
Vagitarian's Avatar
anybody?
Freemananana
Suspension & Brakes
Jul 24, 2014 10:18 AM
KevinEF7
Jul 6, 2013 09:36 AM
SiRay13
Suspension & Brakes
Mar 13, 2006 09:29 PM
AccordCD5
Nov 16, 2004 04:46 AM
