Fuel Efficient 5th Gear Swap
Old Jun 22, 2013 | 03:03 PM
xcdustin's Avatar
Default Fuel Efficient 5th Gear Swap
Looking to gain some fuel efficiency. Have a '91 LX 5Speed (F22A1), and want to swap out the 5th gear for something that can help me pick up some gas mileage on the highway.
Any ideas? I blieve the engine is large enough to handle a failry significant change to a more conservative gear. I turn 3000 rpm at 80 mph, but I'd like 2500 if possible. Thanks for your help!
Old Jun 22, 2013 | 04:53 PM
DeadlockRiff's Avatar
Default Re: Fuel Efficient 5th Gear Swap
There are no gears you can swap to amount to that much of a change.
Your current 5th is .705, 91 LX trans.
To get a 100 rpm drop you can swap to the 91 EX 5th, .685
Anything else would require a custom gear ratio. For 2.5krpm you would need a ratio close to .575 or a lower Final drive which would also need to be custom (Which would affect how the car accelerates completely).
I would suggest looking into LRR tires.
Old Jun 23, 2013 | 07:42 AM
chrisnick's Avatar
Taller, skinnier, LRR tires. Pay attention to weight.
Look at ecomodder.com for more suggestions. There's lots of other things you can do to increase mileage other than a different 5th. I think the 98-02 5-speeds are geared a bit longer, too.
Old Jun 23, 2013 | 08:17 AM
GhostAccord's Avatar
Stop cruising @ 80mph. These cars have a sweet spot for fuel efficiency and that's not it. If you want to save fuel try cruising @ 65-70mph.. That is usually the sweet spot. Besides that, there are no taller 5th gear sets than what are in the F series trans that I am aware of.
Old Jun 23, 2013 | 08:26 AM
The 94-97 & 98-02 both share the same 5th gear (0.685) and final drive (4.062). The 94-97 Accord wagon has a final drive of 4.266 if you want to do any swap that would work.
92eghb
Transmission & Drivetrain
26
Apr 13, 2020 06:34 AM
bcp7272
Honda CR-V & Element
May 26, 2012 09:27 PM
Schurke
26
Apr 17, 2006 08:32 PM
biggdogg
13
Jan 15, 2005 05:08 PM
