looking to mod my accord
Old Jun 21, 2013 | 09:34 PM
TinoTheTygaPR's Avatar
Default looking to mod my accord
got a 94 honda accord coupe auto with a F22b2 wit 170k miles after a tune up(spark plugs up a size, oil change, water pump and timing belt, gasket seals) looking to add horsepower wanted to add a F23A intake manifold and AEM cold air intake maybe change cams. should i do all that and what else? Oh and im not gonna make the swap to a H22 cuz i wanna do all the mods myself and engine swaps are to much of a pain in da azz
Dont have a garage to work on car and not many tools outside of basics and small air compressor
Old Jun 22, 2013 | 02:05 AM
NZXTInerTia's Avatar
Default Re: looking to mod my accord
There have been more than three threads in the past three days asking this same question. Do some damn research people..
Old Jun 23, 2013 | 07:55 AM
chrisnick's Avatar
Assuming your engine's healthy and all maintenance has been done as you've stated, this is what I'd do(and plan on doing for a little gain for little $).
Go junkyard diving. Get your F23 manifold, and try to scrounge up an F22A6 cam. If you like shiny tubes, buy an aftermarket intake; if you want a perfectly capable intake, snag a Prelude intake tube and box, and ditch the factory in-bumper resonator. If you really like pissing money into the wind, go ahead and put a different filter in the box. It'll run off your stock ECU. Since you're an OBD1 car, try to see if you can find an ECU from a 92-93 EX 5-speed, as it will have the proper mapping for the F22A6 cam. You'll have to swap pins A6 and A11 on the harness. All that should cost about $100 at a pick-n-pull. Don't expect to make more than 10-15hp(crank) over what you have. Don't expect any results unless you can get a dyno of before and after for measurements.
Want to make a little more power? Pair it all with an ebay header(no use going anything fancier), exhaust if you want, get a P06 ECU from a Civic, and get it chipped and tuned. The ports of the F22B2 head are the worst of the F-series family and won't really make power past bolt ons and a small cam while staying naturally aspirated. You'll either have to go boost, or do a swap, neither of which it seems like you'd be inclined to do.
NOW SEARCH!!!!
Old Jun 23, 2013 | 08:10 AM
GhostAccord's Avatar
I think it's time to move on to a newer gen chassis.... All these newb threads are hurting my brain!
Old Jun 24, 2013 | 05:50 PM
can i get more power out of my f22 or a h22a cuz i might have to change the trans si while i have the motor out might as well think of a switch
Old Jun 24, 2013 | 06:00 PM
H will make more NA power.
Old Jun 24, 2013 | 07:16 PM
how much can i get an h series motor for or how do i work with a boost
Old Jun 24, 2013 | 08:04 PM
oh and thanks for the advice
Old Jun 24, 2013 | 08:10 PM
19Accord97's Avatar
search....search....search
Mos Jef
Sep 11, 2015 04:05 PM
mike_chomik
Aug 5, 2013 02:12 PM
grat457
Jul 21, 2009 10:38 AM
