Overheating...help
My car has randomly been overheating off and on
I started by replacing the thermostat and it was good for a week. Then replaced the radiator cap and it was good for a couple days. After driving to work 60 miles and back home today, I was almost home and I noticed the car starting to overheat again!
Thermostat has been replaced
Radiator cap has been replaced
What else?!
What else?!
I've been riding in the car all day. I left the radiator cap off last night, put it on this morning and she's been good. I noticed the temperature to up for a little to the halfway mark but it went back down. Where it always stays to halfway between cold and halfway mark. One thing is my ac isn't as cold as it was. Any idea why?
what engine do u have? id assume a v6 if ur pass fan was on while u had the ac on. ur a/c not beign as cold would b cuz ur radiators running hotter than it should since the fan doesnt come on. pull the fan relay and test it id say its gone bad.
most likely ur temperature switch has gone bad. the a/c button gives power to the radiator fan so that explains y that works when the a/c is on, but the condensor fan only runs when the temp switch says the engine is hot. and if the temp switch is bad ur radiator fan gets no power when the a/c is off causing neither fan to work
honestly temp switch is my only guess. from the diagram im looking at ur engine has 2, 1 for a lower temp and a back up for a higher temp. my guess is the 1 for the low temp failed and now ur running on ur back up that only trips at a higher temp
I do know that my car was overheating, had the thermostat replaced and all was good but this guy in a truck backed into me at a stop light (I was behind him) and maybe this made my driver fan loose or only work sometimes.
Seriously how hard is it to watch your fans and report EXACTLY which fans come on and which don't and when. It's really vital that this information be given and accurately. Or you can have people guessing as to what the problem is. If you would have done that already you would have a definitive answer by now.
Or people can keep guessing.
