radiator or other problem
Old Jun 21, 2013 | 05:40 PM
jose hernandez0's Avatar
Default radiator or other problem
My civic 98 ex has been leaking coolent from a bottom holes. At first I chagne the clamp and it stop for like 3 hours then it leak again. The next day I change the hole and it wouldn't leaking if you put the clamp a.l certain way if u put any other way it would leak again. I even took out the radiator to change the tube but no cracks or hole I could have seen. OK so I change the hole work fine for like 3 day the it leak again. I don't know if its the radiator or something else and it leaks form where the rubber hole and tube meet not in the hole
Old Jun 21, 2013 | 06:48 PM
Former User's Avatar
Default Re: radiator or other problem
Post many pictures.
Old Jun 21, 2013 | 07:09 PM
instrument's Avatar
Use two clamps.
Old Jun 22, 2013 | 04:38 AM
axis11's Avatar
Apply some liquid gasket and insert the clamp. Let it dry before you pour in coolant.
Old Jun 22, 2013 | 05:03 AM
HondaPartsHero's Avatar
Technical Hero
You need to pressure test it to see exactly where the leak is, you shouldn't need any type of sealant for it to seal correctly.
goota
Jul 23, 2007 08:22 PM
tommyt761
Oct 12, 2006 01:00 PM
eastsideATX
Jul 6, 2005 02:56 PM
tca0bell
Mar 23, 2005 01:09 PM
SIMATIC
Jan 15, 2004 01:20 PM
