d15b2/d16a6??
Old Jun 20, 2013 | 11:56 AM
Z0831xiz's Avatar
Default d15b2/d16a6??
Firstly thanks everyone for this help i appreicate it!! s there a difference between d15b2 head and cam gear/shaft.
And d16a6 head I have a d16a6 block and a d15b2 head. Its a bad head gasket . And belt is to lose so what belt should I use . And what head gasket should I use?? Even more is it reliable or defective. And of confuse high compression. Any other help would be great!!
Old Jun 20, 2013 | 12:00 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: d15b2/d16a6??
The primary difference between the two heads is the camshaft (springs are different too). They both use the same cam gear. For your specific situation you would use the belt meant for your block since really you'll end up with the same thing as before anyway. Compression will vary depending on what head gasket you use.
Old Jun 20, 2013 | 03:09 PM
Z0831xiz's Avatar
so I should use d16a6 head gasket and d16a6 belt ? and any idea if there different in any way besides b2 dpfi and a6 mpfi?
Posted from Honda-tech.com App for Android
ramboPandA
Sep 21, 2014 06:38 AM
B_Swapped93
Dec 17, 2012 03:07 PM
krysted9354
Mar 23, 2009 07:22 PM
turbocivic1984
Jun 2, 2008 03:03 PM
SPOON_BeIgHtEeNsEe
Jul 7, 2002 01:37 PM
