frozen stabilizer link
Old Jun 20, 2013 | 08:04 AM
leon phelps's Avatar
Default frozen stabilizer link
hello,
2001 accord four door, 4 cyl.
need to remove the sway bar link to replace. just spins on the inside.
Any suggestions? heat? Plasma cut? grinder?
thanks in advance.
Old Jun 20, 2013 | 11:06 AM
kdm3170's Avatar
Default Re: frozen stabilizer link
they're a pain, ur supposed to be able to remove them wit a crowfoot on the nut and a hex/allen wrench in the end of the stud but that usually never works for me. u can try to pop the ball joint apart wit a hammer or pry bar so u can get vise grips on the ball n use an impact gun or just cut it out if u got room to grind it out.
Old Jun 20, 2013 | 12:38 PM
lsvtecEM1's Avatar
X2 on getting a grinder and cut it out , had to do that to both sides a few weeks ago, took 10 mins
Old Jun 20, 2013 | 03:15 PM
MAD_MIKE's Avatar
MM Gruppe B
Use a box end wrench on the nut and a hex driver on a ratchet.
*You will ratchet the allen as though you are tightening it to remove it from the nut*
Or a ratcheting box end with a normal allen key.
Old Jun 21, 2013 | 09:43 AM
cut off tool then grinder. thanks for the help guys.
tried the allen, it was too rusted to get it in there. damn original parts.
Mr.Speed
May 21, 2015 05:57 PM
B_Swapped93
Dec 6, 2013 06:30 PM
MelJ
Suspension & Brakes
Nov 7, 2010 11:48 AM
gnx547
Aug 23, 2010 11:55 AM
TB123
Suspension & Brakes
Mar 11, 2008 02:56 PM
