FS: 2000 honda civic cx turbo $10kobo
2000 honda civic cx
68xxx miles
$10k obo
tuned on vp blue race gas
556whp/365tq
EXTERIOR:
Civic Type R rear bumper chin spoiler
Civic Type R rear wing
Civic Type R mirrors
SI/CTR grill with badge delete
gs-r emblem
NRG Innovations 100 Series lug nuts (#LN-100BL-17)
Konig Lightning wheels 4x100 15x7 +38mm white
Kumho Ecsta XS tires 205/50/15
TCSportline Carbon fiber hood with paint matched sides
NRG Innovations Carbon fiber hood dampers (#HD-110CF)
INTERIOR:
SI cluster
Carbon fiber gauge insert
Kenwood Excelon KDC-X496 CD Player
Alpine Type R Speakers through out
OEM shifter with custom nylon bushing kit from KING motorsports
DC sports Aluminum Shift ****
Autometer triple gauge pillar pod
AEM Digital Boost Gauge (#30-4406)
AEM Digital Fuel Pressure Gauge (#30-4401)
AEM Digital UEGO Gauge (#30-4100)
NRG Innovations steering wheel (#st-006-wt-y)
NRG Innovations Gen 2.5 quick release (#srk-250gm)
NRG Innovations short hub (#srk-130h)
NRG Innovations steering wheel quick release lock (#srk-101gm)
Compustar 2-way alarm with glass break sensor, 3-way sensor and battery backup
ENGINE:
GOLDEN EAGLE Godzilla sleeved GSR motor (1.97L)
Copper O'ringed
84MM CP Pistons
Crower Rods
GSR crank micro polished
Brand knew OEM Honda bearings and gaskets
Type R water Pump
Type R oil pump
Type R timing belt
Cometic headgasket
Moroso 6.5 capacity oil pan
Modern Cylinder head -full race- port and polish
Supertech 1mm over exhaust valves
Supertech .5mm over intake valves
Supertech Titanium springs S
Supertech Titanium retainers
Hondata heat shield intake manifold gasket
Edelbrock Victor X intake manifold
Edelbrock 68mm Throttle body
Edelbrock adjustable cam gears
GSR cams
Red Honda OEM valve cover
King motorsports custom catch can setup
Omni 4 bar map sensor
New OEM Honda alternator
FAL fan
MSD wires
T1 Race Development M&W Pro 10 Kit (ignition box, crane ps92 coil and wire harness)
AVID motor mounts with race urethane
Xenocron ecu with boost control components
Hondata S300 with boost option
AEM Boost Control Solenoid (#30-2400)
FUEL:
AEM fuel rail
FIC 1100cc High-Z injectors with GM clips (#IS115-1100H)
Aeromotive Fuel pressure regulator
-6 stainless fuel feed and return lines
Walbro 400lph fuel pump (#F90000262)
TRANSMISSION:
GSR trans with Quaife LSD
GM Syncromesh
2000 civic SI shift forks with prothane bushings
LS 5th gear
Carbon Synchros
Clutchmasters Stage 4 clutch disc
Competition Clutch Stage 5 pressure plate
Exedy HF01 Chromoly racing flywheel
TURBO SYSTEM:
Inline Pro stainless steel manifold T3 style
Precision SC61 6169E .63 A/R
-4 stainless steel oil feed
-8 stainless steel oil return
One-Fab 3" downpipe with flex pipe
Inline Pro 2.5 aluminum charge pipes
TIAL Blow off valve
TIAL 44mm wastegate with dump underneath oil pan
Precision 750HP intercooler
Full 3" Vibrant exhaust no resonaters or cat
SUSPENSION:
TEIN full coilover suspension with pillow mounts
Prothane full bushing kit
GSR front suspension with slotted rotors
GSR rear suspension with slotted rotors
Russel stainless brake lines
Z-10 traction bars
new lloyd's mats classic loop grey trunk mat 6/11/13 ($79.90 shipped, jc whitney)
new spare tire cover board 6/10/13 ($59.99 shipped, ebay)
new nrg innovations carbon fiber hood dampers 6/4/13 ($149.99 shipped, ebay)
new aluminum spark plug cover 6/4/13 ($49.99 shipped, ebay)
new rear brake pads 5/15/13 ($19.99, autozone)
new rebuilt rear passenger caliper 5/15/13 ($74.99, autozone)
new compustar alarm 4/17/13 ($662.13, automotive integrated solutions)
new gs-r emblem 3/23/13 ($24.80 shipped, ebay)
used m&w pro 10 ingnition setup 3/13/13 ($635.00 shipped, JDM_COUPE hondamarketplace.com)
new kumho ecsta xs tires 3/12/13 ($458.44 shipped, tirerack.com)
new nrg innovations 100 series open ended lug nuts 3/8/13 ($99.90 shipped, ebay)
new konig lightning wheels 3/8/13 ($453.60 shipped, ebay)
new honda blank key 1/24/13 ($5.00 shipped, ebay)
new nrg innovations gen 2.5 quick release srk-250gm 1/24/13 ($132.00 shipped, ebay)
new nrg innovations steering wheel st-006-wt-y 1/18/13 ($129.95 shipped, ebay)
new xenocron ecu with boost control components 9/27/12 ($236.48 installed, king motorsports)
race gas tune 9/27/12 ($550, king motorsports)
new omni 4 bar map sensor 9/27/12 ($100 installed, king motorsports)
aem wideband bung welded to mid pipe 8/17/12 ($40.00, nitro pig racing)
new nrg innovations steering wheel quick release lock srk-101gm 8/18/12 ($124.99 shipped, ebay)
new nrg innovations gen 2.5 quick release srk-250gm 8/18/12 ($138.00 shipped, ebay) *stolen
new nrg innovations steering wheel nrg-st-008r 8/18/12 ($119.98 shipped, ebay) *stolen
new nrg innovations short hub srk-130h 8/18/12 ($86.00 shipped, ebay)
new main relay 8/3/12 ($56.96, napa)
new fic 1100cc ball-style injectors 8/22/12 ($477.75 shipped, extremepsi)
new walbro 400lph pump w/ install 8/1/12 ($164.00 shipped, ebay)
new boost solenoid bracket 8/18/12 (25.00 shipped, ebay)
new aem boost solenoid 8/18/12 ($90.90 shipped, ebay)
used tweeters and cover 7/26/12 ($55.00 shipped, ebay)
new aem wideband gauge 7/26/12 ($199.80 shipped, ebay)
new aem boost gauge 7/26/12 (144.90 shipped, ebay)
new aem fuel pressure gauge 7/26/12 ($199.80 shipped, ebay)
new cd player 6/29/12 ($133.95 shipped, ebay)
new oem cup holder 6/29/12 ($29.89 shipped, ebay)
new battery 6/1/12 ($100, autozone)
tinted windows 5/12/12 ($135, milwaukee auto and sound)
new distributor cap and rotor 5/12/12
exedy HF01 chromoly racing flywheel 3/21/12 ($218.55 shipped, amazon)
clutchmasters stage 5 pressure plate/clutch disc 3/21/12 ($250 shipped, hondamarketplace)
competition clutch stage 4 clutch disc 3/21/12 ($110 shipped, ebay)
68xxx miles
$10k obo
556whp/365tq
EXTERIOR:
gs-r emblem
INTERIOR:
SI cluster
ENGINE:
Copper O'ringed
84MM CP Pistons
Crower Rods
Type R water Pump
Type R oil pump
Type R timing belt
Cometic headgasket
GSR cams
FAL fan
MSD wires
FUEL:
AEM fuel rail
TRANSMISSION:
GM Syncromesh
LS 5th gear
Carbon Synchros
TURBO SYSTEM:
TIAL Blow off valve
SUSPENSION:
Z-10 traction bars
