D Series Turbo Kit And MORE (D&B)
Old Jun 19, 2013 | 12:17 PM
TheToaster's Avatar
Default D Series Turbo Kit And MORE (D&B)
All Prices are fair and do not include shipping. PM me
Will meet up locally (Puyallup, Wa Area)
Cash Talks, Bullshit Walks
25 3-3 30- 161 4
D-Series Turbo Kit
Cast Central Wastegate Turbo Manifold (Media Blasted)
Turbo Smart 38mm Wastegate 10 PSI Spring
Garret AiReasearch T3 60 Trim Turbo .60 Cold .48 Hot A/R 5000 Miles since new. Perfect condition
SpeedFactory Custom 3 in. Mandrel Stainless Steel Downpipe/ Merged Dumptube with V-Band clamp with both flanges TIG welded on to pipe Beveled ready to weld O2 Bung welded at the 10 O'Clock Posistion on the last 90
-3AN Feed Line and Oil inlet flange w/ -3AN to 1/8 NPT adaptor
-10AN Drain line and Oil Return flange Fitted to Oil Pan Tighten and Go
Tapped D16Z6 Oil Pan (Cleaned in Solvent Tank, Bearing Free)
2 Bolt Compressor to 2.5 inch Billet flange with 3 inch intake and K&N filter
All the flanges on the turbo are still attached with the lines so you can just bolt it on and go.
Comes with fasteners
$1500
Info: Wastegate Spring is a 10 PSI spring which will work perfectly with a stock map sensor as well as a stock block.
That will get you ~220 WHP, which is within reliability limits of a stock D-series block.
I made 290 HP at 16 PSI
Full Spool by 2500RPM gives a supercharger like effect, makes good torque
Wastegate is merged with the downpipe in order to reduce audible noise
MAC Valves Electronic Boost Control Solenoid
Assembled with thread tape to prevent vacuum leaks $50
GReddy Type RS Blow-off Valve
Very small nick on the horn, does not impair function Comes with Gasket, fasteners and 3 feet of vacuum line $150
ATP Turbo Type RS Blow-off Valve Recirculation Kit
2.5 inch 90 with 1 inch inlet, 3 feet of 1 inch silicone tubing, Type RS 1 inch outlet $60
Siemens Deka 880cc Injectors with fresh upper and lower seals, Flow Test Results, Media blasted resistor box $250
Skunk2 Intake Manifold
Fits D16Z6 and almost all other D series.
Opened up the TB port to accept 68mm TBs comes with used Thermal Intake Gasket $200
Mishimoto X-Line Triple Core Double Width $300
Fits EG, EK, DC Integra, B series, and D series w/ hose mod
$250 with half-sized radiator
OmniPower 68mm Throttle Body New in box $70
2 inch blue silicone Coupler $5
1.5 inch Filter $5
3 inch T-Bolt Clamps from Go-Auto (2) $10
Long Engine to Tranny Stiffner $10
D16Z6 Valve cover $30
D16Z6 56mm TB with FITV, broken TPS $40
Drivers side Manual EG Mirror $10
Passenger Side Spoon EG Mirror $30
Complete Charcoal Grey Rear Seatbelt set (Left Right, and Middle) $20
EG or EK window washer bottles/pumps $20
OEM Negative battery terminal Ground strap $10
10 and 12 feet of 0 gauge wire with ends on one side $40
6 Feet of 4 gauge wire $15
2.5 feet of 4 gauge ground wire with ends soldered and crimped $10
EG under brace $30
Sparco Harness Bar Fits EG EK DC $350
Crank Pulley (2 Z6's and 1 A6 w/rubber) $30 each
Shorter than Z6 Belt, used for under drive pulleys $10
Z6 Alternator Belt 5k Miles $10
Y7 Alternator Belt (Y7 is a little longer than Z6) 30k Miles $5
D Series OBD2a Alternator w/ Pigtail $40
D16Y7 OBD2a Distributor $50
Stock Map Sensor $10
Stock TPS Sensor (Tip cracked a tiny bit but it works perfect) $5
Stock IAT Sensor (Same as above) $5
OBD2A D16Y7 5 Speed ECU $40
Stock Shifter $10
Lower Timing Gear w/ Belt Guides $10
Transmission Lower Rad Hose Bracket $5
D Series Coolant Pipe (Specify Style) 5$
Thermostat Housing $10
Coolant Neck (Cylinder head part) $10
Stock Jack $10
Engine Mounts/Brackets (Specify) $10
EF Headlight Switch and dash dimmer and defroster switch $5
EG AC Harness Uncut $20
Machine Shop Balanced and Resurfaced D Series Flywheel $50
New Valve Stem Seals (8*) $5
New D16 Thrust Washers $2
Z6 Throttle Cable Bracket $5
D16Y7 Throttle Cable $5
Alternator Power Wire $5
Alternator Tensioner Bracket $5
Alternator Mount $5
Reverse Light Switch $5
Spark Plug Wire Bracket $5
ECT Sensor $10
Water Temp Sending Unit $10
Oil Pressure Sender (Back Of Block) $10
T3 Turbo Oil Drain Flange $5
Complete D16 Y7 Intake Manifold $50
Strange JDM Alternator OEM disconnect $5
JDM B-Series Alternator w/ pigtails and brackets $50
JDM B-Series Intake Manifold w/rail FPR IACV $80
JDM B16A VTEC Cams Oiled and Bagged $50
Battery Terminals $5
D16 EG Rear T Bracket $10
If you need any metric bolts, let me know the head size and approximate length. I have all kinds of stuff PM me.
Old Jun 20, 2013 | 08:25 AM
TheToaster's Avatar
Default Re: D Series Turbo Kit And MORE (D&B)
Bump
Old Jun 24, 2013 | 08:15 AM
TheToaster's Avatar
bump
Old Jun 25, 2013 | 06:25 PM
TheToaster's Avatar
Taking offers on all!
Old Jun 25, 2013 | 06:46 PM
grumblemarc's Avatar
The Grumpiest
Manifold & downpipe. How much?
Old Jun 27, 2013 | 11:52 AM
TheToaster's Avatar
Bump
Old Jun 28, 2013 | 10:48 AM
TheToaster's Avatar
Bump
Old Jun 30, 2013 | 05:15 AM
jman831's Avatar
Will you take $800 for just the turbo kit? Plus shipping to Abilene, TX?
Old Jun 30, 2013 | 06:52 AM
TheToaster's Avatar
No.
bump
Old Jul 1, 2013 | 08:22 AM
TheToaster's Avatar
bump
Old Jul 2, 2013 | 07:22 PM
TheToaster's Avatar
bump
Old Jul 5, 2013 | 10:33 AM
TheToaster's Avatar
bump
Old Jul 7, 2013 | 05:26 PM
TheToaster's Avatar
bump
Old Jul 9, 2013 | 04:59 PM
TheToaster's Avatar
bump
Old Jul 12, 2013 | 04:36 PM
TheToaster's Avatar
bupmp
Old Jul 14, 2013 | 10:55 AM
TheToaster's Avatar
bump
Old Jul 15, 2013 | 04:43 PM
TheToaster's Avatar
bump
Old Jul 18, 2013 | 08:15 AM
TheToaster's Avatar
bimp
Old Jul 21, 2013 | 12:05 PM
TheToaster's Avatar
bump
Old Aug 3, 2013 | 10:16 AM
TheToaster's Avatar
bump
Old Aug 3, 2013 | 10:35 PM
mitsuman's Avatar
Bump for a fellow dso'r
Old Aug 7, 2013 | 06:16 PM
NaveLB's Avatar
Got any more pictures of the oil pan?
Old Aug 7, 2013 | 10:19 PM
Christo19's Avatar
I want that turbo
Old Aug 8, 2013 | 08:58 PM
Christo19's Avatar
Any chance you want to sell the turbo only let me know!
TheToaster
Oct 28, 2013 06:55 PM
TheToaster
Northwest (Sales)
Jul 14, 2013 10:56 AM
rjmancia
Jan 4, 2009 07:05 AM
