Semi built D16y8 runs hot... Need advice
Old Jun 19, 2013 | 02:52 AM
DelSolMike's Avatar
Default Semi built D16y8 runs hot... Need advice
So my semi built D16y8 runs hot. No air pockets. System was bled correctly. Temps average 205-215. 220 is as hot as it gets. I know I'd like to be around the 185 area but I think this has to do with my GE block guard, Fluidyne radiator and AC fan I run for my radiator.
Now I know it's hotter than it should be, but is it dangerous? What temps should be really be concerned about? I feel it's about time I upgrade my radiator too... Any suggestions for a nice half sized with a thicker core and fan? This is for a del Sol.
Thanks!!
Old Jun 19, 2013 | 05:25 AM
BigMike0147's Avatar
Default Re: Semi built D16y8 runs hot... Need advice
Do you have any water wetter in the system? That will typically drop a couple of degrees also.
Old Jun 19, 2013 | 07:50 AM
DelSolMike's Avatar
No.
Old Jun 19, 2013 | 03:52 PM
crvtectim's Avatar
Why not run the radiator fan with shroud instead of the smaller A/C fan? Clearance issues?
Old Jun 19, 2013 | 05:16 PM
DelSolMike's Avatar
Yes, I needed a slim fan and had it laying around.
I think I may go the Mishimoto X Line route with Mishi thermostat, fan switch and thin fan.
Old Jun 20, 2013 | 04:53 PM
crvtectim's Avatar
Just keep in mind, the fan shroud is critical.
adamrich33
Apr 2, 2012 04:00 PM
milkypros
Aug 10, 2011 03:17 PM
g2turbo
Oct 16, 2009 07:36 PM
91EF919
Apr 4, 2009 12:12 PM
the.hamburglar
Mar 17, 2007 08:03 AM
