help with crx code 9 b18a1 swap.
Old Jun 18, 2013 | 11:38 PM
civicb1812345's Avatar
Default help with crx code 9 b18a1 swap.
ok guys so i have a code its throwing 9 and ecu only flashes when the engine is runing, this is a tdc sensor in distributor, i went and got an oem replacement and still nothing. its runs fine except for the ocasional stutter and bad idle, only happens about once a day and is very random, ive checked all wiring have new plugs wires and still cant figure out the problem!!
Old Jun 19, 2013 | 09:06 AM
Default Re: help with crx code 9 b18a1 swap.
cmon guys this is really stumping me and the check engine light freaks people!!
Old Jul 20, 2013 | 10:07 PM
bump...
Old Aug 18, 2013 | 11:08 PM
bump...
Old Aug 18, 2013 | 11:26 PM
EFmine's Avatar
was the car originally DPFI? or mpfi(si)??
has the car been running or has this problem happened immediately after swap?
lsdisk0's Avatar
have you tried switching out the ECU with a known good one to test if its your ECU?
Old Aug 18, 2013 | 11:34 PM
car was a dx orignally, got the car swapped but i can tell the dist. wires have been cut, and no ihavent tried the ecu, no where to get one and no money to afford one.
Old Aug 18, 2013 | 11:37 PM
EFmine's Avatar
make sure the dizzy wires are hooked up properly, dx had 5 and si had 7
the extra 2 are directly related to cam/crank positioning, due to the fact that its 4 injectors instead of the factory 2(dx)
Old Aug 18, 2013 | 11:46 PM
lsdisk0's Avatar
im sure i know someone that has a spare ecu that can run with a b18a, ill ask around plus, either way its nice to have some spare parts!
Old Aug 19, 2013 | 01:32 PM
alright man thanks if you could help out thatd be awesome. and is code 9 one of the wires you have to wire in or cut and swap? ive the the dpfi to mpfi write up and looked at my ecu wires looks like not of them have been cut, unless the depinned them
Old Aug 19, 2013 | 07:29 PM
another thing idk if it has anything to do with this is car burns quite a bit of oil (1-2qts a month) and my coolant is disapearing. ive notice my overflow is always full too. even if i empty it.
Old Aug 19, 2013 | 08:44 PM
EFmine's Avatar
Just double check your Dizzy --> ECU wiring
took me 2 trys to get mine right
DX to Si was nothing less than a headache
Old Aug 20, 2013 | 06:00 AM
if i mixed up those 2 white wires would it still run? i think that may be my case
Old Aug 20, 2013 | 10:40 AM
swappedefloveit's Avatar
I personally had the two white wires swapped. Didnt run right. Swapped em runs like a champ.
Old Aug 20, 2013 | 06:22 PM
thanks ill try that^^
Old Aug 21, 2013 | 08:59 AM
anyone kow how to depin the distrinutor plugs? i have wires soldered and heat shrinked would be alot easier if i could just sepin the dist. plug
Old Aug 21, 2013 | 06:09 PM
http://i.ebayimg.com/t/DISTRIBUTOR-PLUG-OBD0-INTEGRA-CIVIC-WIRING-HARNESS-HONDA-ACURA-88-91-/00/s/MTA5MlgxMjM3/z/9k0AAMXQLs5RqW~j/$T2eC16d,!yUE9s6NFmWRBRqW+jcQ3Q~~60_35.JPG
Old Aug 21, 2013 | 09:37 PM
white wires were right, blew fuse and wouldnt start when i switched them. car drives fine 75 percent of the time, other time its stutter and spirts and cuts out hella and will unless i go wot. then its fine. seems like new plugs helped a bit too. im stumped
civhatch90
10
Mar 2, 2006 05:00 AM
bryse68
20
Sep 26, 2004 01:16 AM
Hcivic88
17
Apr 27, 2004 09:23 PM
RotiEatter
Jun 26, 2003 07:13 PM
CRXBoy
Jan 10, 2003 08:03 AM
