ZC Vtec parts
Hey guys,
I just bought a ZC SOHC Vtec obd1, when it gets here, I'm planning on changing the timing belt, as well as any seals that show leakage. What are the equivalent parts?
I've read that the zc vtec is virtually identical to the Z6, with the exception of the cam. So should I just be getting parts for 93 ex?
I've been searching the forum, and google, for a while now. There isn't a lot of info on zc sohc vtecs. I didn't find any definitive answers, so I figured now would be the time to throw up a thread.
Thanks in advance
Thanks in advance
yes order parts as if it were a z6 any yr civic 92-95 ex or hatch si... id recommend changing the rear main seal would be a good idea while the engine is out away from the transmission. its a ten dollar seal and gives piece of mind for a while ... to change it u have to remove the whole trans for a 10 dollar seal. get a valve cover gasket kit. I would freshen it up with a full gasket and timing belt kit before throwing it in
CaliforniaDad
Mar 25, 2012 10:35 PM
B18C5-EH2
Sep 29, 2007 11:21 PM
Dohc 4door Rye
Feb 26, 2006 08:27 PM
