jdm 98 itr engine into 00 si
Why would you want to run a 1.6 liter less aggressive map on a 1.8 liter more aggressive engine? Not safe to do. You need the p73 ecu or convert to obd1, socket and chip a obd1 vtec ecu (or one that can be converted) and get a p73 map burned to it. Easier and most cost effective way, is to just buy a p73 ecu on ebay. There are plenty on there.
thanks for your input and yes i do have a a p73 ecu but i forgot to mention
if i were to smog can i just pop in the 00 si ecu or would it really be bad for the engine? (mostly using the si ecu for smog purpose )
Don't bother. It will never pass.
https://honda-tech.com/forums/showthread.php?t=3031411&styleid=14
I don't understand this or the last few posts.
Rock the original head with whatever bottom end.
Make everything 100% legit under the hood.
No smog tech will even ID the engine block/cylinder head unless your $#!T looks rices out under the hood. Ex.
Ditch the red valve cover.
Have correct evap with correct routing.
Nothing aftermarket under hood.
Remember it is a factory twin cam car that can fool even a tech semi-savy with Hondas.
If you can't do this^ then no Honda in California for you.
Cause it's not that hard.
I wouldn't trade our Cali smog laws for these rusted out hunks of **** I see in these other states.
I don't see how you can speak for every tech in all of California. Glad you got yours to pass but you cannot guarantee that for everyone.
