NY: 98 gsr turbo for sale
Old Jun 18, 2013 | 09:32 AM
CrazcJ's Avatar
Default NY: 98 gsr turbo for sale
98 integra gsr turbo
3k on the motor since rebuild
200+ on the body
MOTOR:
stock bottom end
arp head studs
blox valve springs and retainers
TURBO:
pte4431re only 2k on the turbo (NO SHAFT PLAY)
log manifold
3 inch down pipe
fmic
TRANS:
light weight flywheel
stage 3 clutch
STANCE:
2.5 inch drop
rotas
ECU:
hondata s300 with boost (running wastegate spring pressure 7psi)
440 low impedance injectors w/resistor box
(stock injectors will be provided as well as stock ecu with purchase for NYS inspection)
aem wideband and aem boost gauges
car has a thermal 3 inch exhaust
2nd o2 is simulated
as of right now the car has a conservative tune so i can drive to and from school over 40 miles away. air/fuel ratio set 11.8-12.0. the car can be NYS obd2 compliant in under 10 minutes and pass state inspection with no issues.
asking $6500 but i am flexible. not willing to part car out as of right now
pm for more info
Old Jun 20, 2013 | 08:47 AM
CrazcJ's Avatar
Default Re: NY: 98 gsr turbo for sale
bump it!
Old Jun 21, 2013 | 06:48 AM
boofunit's Avatar
bump!
Old Jun 26, 2013 | 12:41 PM
boofunit's Avatar
bump!
Old Jun 27, 2013 | 09:28 AM
XpL0d3r's Avatar
that's not conservative, you're just wasting fuel. GLWS though!
Old Jul 1, 2013 | 02:25 PM
boofunit's Avatar
Bump
Old Nov 26, 2013 | 04:24 AM
CrazcJ's Avatar
bump
boofunit
Northeast (Sales)
Jan 12, 2014 11:11 AM
boofunit
Jan 8, 2014 03:18 PM
CrazcJ
Nov 26, 2013 04:21 AM
gringotegra
Jun 1, 2010 06:08 AM
