NY 98 gsr turbo for sale
98 integra gsr turbo
3k on the motor since rebuild
200+ on the body
MOTOR:
stock bottom end
arp head studs
blox valve springs and retainers
TURBO:
pte4431re only 2k on the turbo (NO SHAFT PLAY)
log manifold
3 inch down pipe
fmic
TRANS:
light weight flywheel
stage 3 clutch
STANCE:
2.5 inch drop
rotas
ECU:
hondata s300 with boost (running wastegate spring pressure 7psi)
440 low impedance injectors w/resistor box
(stock injectors will be provided as well as stock ecu with purchase for NYS inspection)
aem wideband and aem boost gauges
car has a thermal 3 inch exhaust
2nd o2 is simulated
as of right now the car has a conservative tune so i can drive to and from school over 40 miles away. air/fuel ratio set 11.8-12.0. the car can be NYS obd2 compliant in under 10 minutes and pass state inspection with no issues.
asking $6500 but i am flexible. not willing to part car out as of right now
pm for more info
200+ on the body
MOTOR:
stock bottom end
arp head studs
TURBO:
log manifold
3 inch down pipe
fmic
TRANS:
stage 3 clutch
STANCE:
2.5 inch drop
rotas
ECU:
2nd o2 is simulated
pm for more info
ECU:
gringotegra
Jun 1, 2010 06:08 AM
