D16A6 Head
Old Jun 17, 2013 | 10:46 PM
Purfect's Avatar
Default D16A6 Head
Okay, so i have a D16A6 Block.. but im to cheap to take it to re-set the valve seats, Could i use a D16Y7 Head for it?
Or should i just go buy another head? Which head will fit?
Old Jun 18, 2013 | 12:18 AM
Z0831xiz's Avatar
I'm unsure of this but I've been told the d16a6 head is the same as the d15b2 head. so I've read and been told. but not sure completely.
Posted from Honda-tech.com App for Android
Old Jun 18, 2013 | 12:26 AM
Purfect's Avatar
Default Re: D16A6 Head
Im not sure on that one.. I know the D16Z6 Head will fit, But my trouble is.. i have a D16Y7 Head.. unused..
But i know there is 1 more.. I just couldnt remmeber which D it was though.. I thought i heard/read somewhere on here.. That any D series would work as long as it was the same year.. So 89-91.. But id like to get it confirmed before i go to the Pick and Pull.
Old Jun 18, 2013 | 01:13 AM
Z0831xiz's Avatar
well the common d series in USA on ef civic was either d16a6 for si hatchback. si crx . and Lx/Ex sedan. were all Obd0 MPFI 88-91 ( except 88 si hatchback as there is none.)
but the other models had d15b2 DPFI Obd0 88-91 sedan Dx . hatchback Dx and STD . and crx HF and STD (or which ever other it is.. )
those are the only ones I know of most commonly in USA.
Old Jun 18, 2013 | 01:17 AM
DCRB's Avatar
yes you can use the y7 head bolts right up
Old Jun 18, 2013 | 07:35 AM
Purfect's Avatar
Thanks
I just posted it in the civic area and got a respond a little quicker..
But D is a D.
thanks again
Old Jun 18, 2013 | 09:57 AM
jlicrx's Avatar
to use the Y7 head, you will also need a Y7 timing belt and a Y7 valve cover
Old Jun 18, 2013 | 11:52 PM
Purfect's Avatar
Thanks, My brother is being a douche canoe.. and wont let me grab his head..
So i just on craigslist and im just guna go pick up some heads from the area.
All rather inexpensive. So i figured might as well get more than 1. while im out and running.
^but good info just in case i do end up grabbing a Y7 off craigslist.
(no one verified what head they got, just said D Series.)
Pippen_001
Oct 28, 2008 12:00 PM
Eg6_JDM
Oct 21, 2002 05:47 PM
