BorgWarner 72mm SFWD Class Limit Turbo
I've been running this turbo since Fall Nats.. Went my personal best MPH on my second pass (172mph) with it. Spools a lot faster then my S400sx 71mm with the 83mm turbine wheel.
I have the S400sx71mm and I am sick of it!
I trapped 148 and cannot go over. Jenna trapped 152 in my car I can't get it to do it again!
PS: Are they really going to maintain this $1000 gap between the 67 and 72mm units??
I would not buy that $2,200 for, I tested the borg 67mm turbo its smaller than my PTE6785 and that thing is so laggy , its junk you dont even need boost controler just a high and low switch for boost. Not to mention the junk bearing that come stock are 270* bearing ate them right up! 3 runs and shaft blew up, they said i need a -6 line...lol
As far as the good ole 372 I trapped 167 last year with one, they are older technology then all the new stuff that BorgWarner offers ... The new 72mm is a great deal for 2200.00 a lot of other turbos you would have to add 1000 bucks to that price tag, and with it being cast wheel drop a 100 pounds off at most events on east coast...
im sure its laggy if it went up in 3 passes ... it more then likely had issues before you put it on lol... as far as -6 line I have never heard anyone at Borg Warner recommend that. If your went up in 3 passes your doing something wrong... more then likely trying to run too much boost knowing you... you really want to start a borg vs precision which turbo takes a crap sooner contest?
I talked to them they said to run a -6 line cause bla bla bla....they didnt want cover it. Im not running too much boost, the turbo only makes 40-35lbs, if i buy a turbo i expect to run that without having any issues after a few passes. I went 9.0@165 on the 2nd hit with the turbo, don't get me wrong it works, but for how long? The old s372 lasted me for years, I also went 168 with the old s372, used the same oil line when i was using the 67mm. The turbo only had a few passes it total.
At fall nationals, ran consistent 9.1@168 and at WCF ran multiple 171+ mph with this turbo.
I can't wait to give it another shot with the new car.
Before this turbo, I ran the BW s400 67mm FMW. Had nothing but success that turbo.
For that price it's a bargain!
I'm pretty sure Cole Marmon from Speed Factory is on this turbo as well.
I was fortunate enough to test this turbo last year as well. I have the cast version.
Pretty sure cole was running that turbo at vegas!
im sure its laggy if it went up in 3 passes ... it more then likely had issues before you put it on ...As far as the good ole 372 I trapped 167 last year with one, they are older technology then all the new stuff that BorgWarner offers ... The new 72mm is a great deal for 2200.00 a lot of other turbos you would have to add 1000 bucks to that price tag, and with it being cast wheel drop a 100 pounds off at most events on east coast...
this turbo is 100% borgwarner... engineered in their lab. the forced inductions version uses one of the mystery compressor wheels, machined and assembled by them (completely different) and does not use the same 72mm compressor or 87mm turbine wheel
looking forward to seeing the new car out this year paul!
something does not make sense here - that s372 that lasted you years is the same turbo as the S400 67, only difference is compressor wheel... same bearing housing, same thrust surface, same turbine wheel and shaft... also i dont know who you spoke with but I recommend -4AN or -6AN oil feed line with a restrictor. i would never recommend -6 feed line without restrictor. If you dont want to use a restrictor use -3AN feed line. technically Its best to use larger dia so the oil gets to the turbo faster upon startup but tons of people use -3 with no problems.. if you still have the 372 i can help you fix the 67 or if you need replacement parts i can help with that too..
agreed
agreed
Yeah that's what I said it's the F-I version which makes more power due to "mystery compressor wheel" and is available with a 92mm turbine. :-P
I agree with Geoff .. you said how durable your 372 was but the 67mm went up in 3 passes .. doesn't matter you will never admit what hurt it... I blame the user .... I have run more of these same turbo's then I can count on everything from cobalts, honda's mustangs etc... they are reliable great bang for the buck... arod you guys break more **** then anyone .. clutches motors , say it aint so.... it doesn't matter you will have some reply , but just remember to read what you say cause you contradict your self a lot.... and once again nobody from borgwarner told you to run a -6 ... I have run -3 and -4 never had any issues , unless I had foreign object damage...
regardless it should be easy to replace the bearings, and the turbine shaft, and be back up and running. thats a big benefit of the BW s400, ultra simple and easy to overhaul
