Aftermarket ITR brake components for CR-V RD1?
Hello HT members, i want to ask you something about my CR-V 1st generation. Cuz on the market are almost zero aftermarket brake components for CR-V like lightweight brake discs, calipers, pads and ss brake lines....can i use ones that are for ITR ? I mean only for front brakes. Already checked the OEM part numbers but they a little different. I want to buy some better brake discs and pads and after some months calipers too. All that cost a lot of money and i don`t want to play a roulette
Can anyone give me some advise ?
As most of the parts, brakes will probably be the same as up to 00 civics and old integras.
I think Brembo site has very good info on the measurements, etc, as they make a lot of stock size brake components (mostly rotors).
If in doubt, send a message to the seller and ask them to measure all the diameters and thickness. (Hopefully someone here has more info.)
i know this has been covered, but since thats answered and its a brake topic, is there anyway integra trailing arms will work for rear discs? they look the same the only different i know of is the crv has a bit bigger bushings. obviously not 4wd compatable, but anyone tried it or compared the 2 yet?
CR-V uses the same bushings as the civic/integra, the arms themselves are completely different.
On FWD models you should just be able to swap over ITR rear spindles, hubs and calipers.
thats what i was asking thanks.
but you are incorrect about the bushings, i know because i was accidentally shipped cr-v bushings for a civic when i was doing a rear disc swap. they are just slightly bigger its almost impossible to tell the difference until you go to press them in and they dont fit. i went to honda and they confirmed this and i got new bushings and they popped right in.
