My 90 civic hatch build!
hey guys, so this is my 90 civic dx. picked it up a few months ago and finally getting started on the build! gonna be a mild stance/track car one day.
I picked it up with a d16a6 swap and skunk2 coilovers. pretty stock other than that.
here it is the day I got it home
ran pretty well. but had a oil slight leak. and for whatever reason he had the front motor mount in the trunk. and there is practically no 2nd gear, if im not on the gas in 2nd it pops right out.
got the front mount on.
getting some gas
so after about 2 days of driving it, I ended up having a pretty big coolant leak. ended up being one of the bypass hoses. replaced that and than another coolant leak started after one drive..thermostat gasket was ripped, as well as the radiator was leaking at the radiator neck
replaced the thermostat and got a new radiator as well as battery because it died on me..this all within about a week of purchasing.
new radiator
new upper and lower radiator hoses, as well as battery
draining some coolant for the install
bad thermostat gasket, probably hard to see the tear.
after I finished all this car has been running pretty well since. it sat for a while until recently.
got some 15x7 0 offset diamond steelies for it. 185/55/15 hankook tires.
she now sits like this
front fenders are slightly pulled but do need some more, and I just today ordered camber kits to tuck those rear wheels in a little and probably lower the car a little more.
a few days ago I got some function 7 control arms in the mail and put those on
that's about all for now till my camber kit arrives.
than gonna start gathering swap parts pretty soon. ill keep ya guys updated and hope you can enjoy my build! I know I will. thanks for looking!
getting some gas
new radiator
okay guys got an update for ya! camber kit arrived today, im gonna try to get in on by the weekend, just gotta find time around work to install and go down for an alignment. heres some pictures!
got the kit from hardrace. heard good things about them
and I also got a new camera, all the pictures you've been seeing are taken with my cell phone. so now this thread will hopefully be filled with a lot more pictures, and better quality!
the camera
ignore the sideways and upside down pictures for now, haha that will be fixed soon.
ill try to keep you guys updated more often, don't always get much time with work!
the camera
anoter update! I got the camber arms on tonight, adjust with the ride height just a little and worked on getting the camber as even as I could by eye, got it close enough to drive it down to the shop to get an alignment and they'll make it perfect! I will have pictures tomorrow of the process and before and afters!
I got a question for you guys though, are most shops okay to work on aftermarket camber arms and adjusting them? or do you guys know of some that are better than others? just curious, I don't wanna run into problems!
ill keep ya posted!
ill keep ya posted!
Looks pretty good for an old EF. I'd keep it looking as clean as possible. Don't change the paint color, it's a pain painting engine bays haha.
Good buy, I'll watch the thread.
thanks!
okay guys update! sorry it took so long, had some things come up with my daily and had to get that sorted out. however till I get it back, last couple days ive been taking the hatch to work, getting her out of the garage.
anyway here we go
so as I left off, I went ahead and got the camber arms on in the rear
old.
taken off.
old to new.
on the car.
these were all pictures from the left side, right side went a little smoother than the left actually. one of the bolts on the left that threads into the body of the car was a little stubborn and I had to put pressure on the wrench and slowly work him back in,
but I managed to get it back in and torqued down
heres some before and after pictures of the car.
before
after
different angle before
after
from behind, in this picture I had only adjusted the camber so much, you can tell the right has more negative than the left.
just took care of it the next day at the alignment shop cause it was easier.
shes got something on her shoes in this one..what could it be..
soo the final camber was set at -3.2 up front and -4.3 in the rear..
since I had to been driving her to work here are some pictures
my friend did some editing
another, no editing
peak a boo at work, with some editing effects
and that's all for this update guys! might be on hold for a little due to the issues im having with my other car, gotta get it worked out first.
but parts will be coming in soon again shortly, as well as more pictures and fun!
thanks for looking!
anyway here we go
old.
taken off.
old to new.
on the car.
before
after
after
another, no editing
thanks for looking!
edit: it looks like an ebay lip such as this: http://www.ebay.com/itm/88-89-90-91-Honda-Civic-EF-5DR-5D-Wagon-CS-Front-Bumper-PU-Lip-URETHANE-Body-Kit-/261178097879?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1990%7CModel%3ACivic&hash=item3ccf6d80d7&vxp=mtr
hey guys, sorry no update for a while. so heres what ive got going on. car was giving me problems left and right, so its time for the swap and clean up
picked up a swap. b16a all stock and y1 trans. came with chipped pw0 ecu as well as a virgin pr3. brand new hasport mounts and shift linkage. wire harness from a ef sedan. wire harness that was on the b16. axles and a few other parts, but ill probably end up getting new axles when it comes time to put it in.
got the old motor pulled out today
half way there
all done
that was about all I did today.
plans are to now start cleaning up engine bay as well as collecting a few more parts for the swap.
ill be keeping you guys updated!
half way there
all done
Not sure what you are referencing, but my local alignment shop does it for $49.99. I replaced both outter control arms and the toe was way out. I also put on larger rims and tires. No problem, still 50 bucks.
Peppyz
Mar 1, 2016 06:00 PM
