Stock b16a with Skunk 2 Cam Shafts
first thing i want to do to my head internals with upgrade my camshaft. if i get an aftermarket camshafts what performance does it imporve to your first gen jdm b16a?
Performance cams perform much better with high compression. Use a stage I if staying stock.....anything more aggressive will not net the results you are looking for unless you build your bottom end using higher comp pistons
thanks, i was thinking of turbo charging a stock b16a, but im afraid i might blow my motor quick. so thats why i'd rather just change up the camshafts for more kick to the motor.
back to your original question; before you do camshafts, it would be wise to do the valve springs, or both at the same time.
in regards to the transmisssion, i have a cable B16 S1 trans with Wavetrac LSD, no problems with the short gears and i drive the car everyday. the talk about the transmissions is just talk. the only transmission i wouldn't run is the YS1 from the B17.
if you decide to go turbo, do a lot of research. I personally would advise against buying a used kit or turbo if you don't know what to look for. buying a new kit will eliminate a lot of problems. i pieced mine together, learning a lot as i went. shouldn't have to start new threads with turbo related questions as there are plenty out there that will answer your questions. make sure you do a lot or research and a lot of reading
blu_civic = good info
honestly before you dump money into a b16 NA....do research and see who much money is spent on it just to get it into the 180whp range. for the same (if not less) money you can build a LS block from scratch and end up with more overall tq & whp.
I have like 3 old b16 block in my garage. one day i'll get around to doing somethign with them. probably try different setups like stroker na, stock stroke na, & turbo block
as for cams i would go with 00-01 itr cams they can be found for $300-350 & easy drop at 0/0, set lashing and go.
as for springs i would go with RMS SL springs & stock seats/retainers... $150.
LS or B20 vtec is your best bet for making power N/A when starting out with a B16. Otherwise, about $3k for a turbo B16 or more $ for N/A B16 making about 200whp.
b16 and b18 have the same piston diameter and combustion chamber diameter, which is why you can use a b16 head gasket. LS-v would definitely be a good choice for some cheap power over what you currently have. you could even use the b16 pistons in the ls block for some higher compression around ~ 12:1
spencerxfr3sh
11
Jun 11, 2009 11:24 AM
