Wrong head on block need help
Hey guys I'm back my problem this time is my 94 accord ex with a F22b1 snapped the timing belt and screwed the valves in the head so i had it towed to my mechanic for a head well i bought a new head had it rebuilt resurfaced and all they installed it with with a new timing belt kit and head gasket it fit perfect but we just realized its a f23a1 head and we put it on a f22b1 block now it fit perfect lined up perfect but the distributor from the b1 wouldn't fit so i bought a 2000 accord distributor and it doesn't match the wiring harness as in my wiring harness has 2 plugs and distributor only has one and idk if it even fits in it yet is there any thing special i need to do or get and what else should be done to make it run because im about to junk it lol
i believe the bolt holes/mounting ears don't match up. if i were faced with this on a car i was trying to get running, i would just fab up an adapter flange or some bracketry to make the B1 distributor work.
if i change my head gasket and mark exactly the position of ea screw on my distributor will the timi
civicracer1993
Nov 8, 2002 09:38 PM
