No code, but severe hesitation, once a day or 2
Old Jun 14, 2013 | 04:32 PM
verynew2honda's Avatar
Default No code, but severe hesitation, once a day or 2
Hello. as you can tell, I am new to the Honda world.
My daughter presented me with her 95 Civic,with a 1.6 non vtech, after taking it to several shops, and asked me to look at it. She gets a hesitation every couple of days,sometimes the cel light comes on then goes off and no code is stored.
The shops have changed the cat. converter, distributor, as well as brakes, master cyl. and clutch.
When I first looked at it, I found loose spark plug wires, oil in spark tubes and a loose spark plug, as well as a very dirty air filter.
to eliminate normal problems, I changed the valve cover gasket and tube seals, new plugs, cap, rotor, wires, fuel filter, pcv, and air filter, as well as an oil change.
It runs much better(go figure) but still has this intermittent problem.
I hate to be a parts changer, so if anyone could help, I would appreciated it very much.
verynew2honda
Old Jun 18, 2013 | 01:51 AM
Buckshot870's Avatar
Default Re: No code, but severe hesitation, once a day or 2
Noticed no one has responded in a couple days. I would suggest a couple more free / low costing possible solutions.
Clean the throttle body
Clean the EGR port
Make sure you have up to par spark plugs, I suggest NGK
Other suggestions would be your throttle position sensor, and your fuel injectors.
If it isn't any of those, then I'd be surprised!
Also is it idling high at all?
Old Jun 18, 2013 | 05:00 AM
Joshka89's Avatar
You need to check that CEL as soon as it comes on.
You can either use the smartphone OBD reader or just jumper the CEL and read the code.
Even if you're/she's driving, safely pull over and get a code.
Have you driven this and felt the hesitation?
Is it when you put it in gear? Put a load on it?
Old Jun 24, 2013 | 05:06 AM
Thank you ,Buckshot870, I have cleaned the throttle body, as far as I can tell, it has no egr valve, I have checked the tps, less than 1 volt static, 4.5 wot. Re-pulled the spark plugs and they are clean.
Thanks Joshka89, I have given her a paper clip and instructed her on its use. After the last time I looked at it, pulling the plugs checking connectors etc. it has not happened.
I am hesitant to say fixed, but on hold for now.
Thanks again!!!
Old Jun 24, 2013 | 09:38 AM
01hondacivic's Avatar
Default No code hesitiation upon cold start acceleration
I have a similar problem with my 01 Civic EX. It has 120,000 miles. After a cold start, during acceleration both the first and second times I hit about 2800 rpm's there is hesitation ( loss of power ). If I continue to press accelerator problem worsens. I take foot off gas pedal and then may accelerate again until the second time I hit 2800 rpm's whereupon there is another hesitation. After the second one car runs great until the next cold start. The check engine light does not go on and shop says no codes are indicated.
Shop updated computer ( ECM-PCM ) but problem persists. This started intermittently a couple of months ago but is now every time I engage a cold start. Unfortunately, when I took it to the shop and left it over night, they did not experience this.
Old Jun 24, 2013 | 10:09 AM
grumblemarc's Avatar
The Grumpiest
This isn't the '01 forum.
Old Jun 24, 2013 | 01:09 PM
charliccs's Avatar
check the oxygen sensor...
once in my civic d16y8 I was having hesitation in the range of 2000 to 3000 rpm without CEL.
I changed a varity of thing´s without success...
then changed the oxygen sensor and problem solved... (like I said before no check engine light).
Old Jun 24, 2013 | 03:03 PM
Toofpik's Avatar
^ Same thing happened to me with my o2 sensor
Old Jun 24, 2013 | 03:21 PM
b20VAngel's Avatar
could be a faulty throttle position sensor that wants to give out.
Old Jun 24, 2013 | 03:56 PM
Ryan Lwin's Avatar
It's most likely the O2 sensor. It's not telling fuel injectors to spray enough fuel into engine.
Old Jun 28, 2013 | 09:01 PM
chillerice's Avatar
Which one of the sensors? Upstream or down? Cause my Y8 has been doing the same hesitation under 3k rpm or from a stop.
I just want to know for future cases as it's too late now with a rod knock caused my first owner running the car oil low & not changing it either just adding = hella sludge). Found this out just now years later
Old Jun 28, 2013 | 09:04 PM
Ryan Lwin's Avatar
Depends on the year. Most likely the one on exhaust manifold. There's only one O2 sensor in 92-95 models.
Old Jun 29, 2013 | 10:57 AM
chillerice's Avatar
Mine's 98. Will check it out though as i'll be using back my dc header when I replace the motor.
Kinda figures too because my brother changed the header just before parking the car for 1.5 years so the sensor probably old & never changed or faulty.
Thanks.
Old Jul 1, 2013 | 12:35 PM
Thanks again for all the advice, the problem has yet to re-surface, so for now I am going to say it is fixed.
As far as using the words help, and best, I do not believe this makes anyone sound stupid. If someone needs help, does that make them stupid??? If someone does the best they can, does that make them stupid??? Or are they lazy for not wanting to perform tests that are not called for???
I think someone is waaaaaayyyyy 2 grumpy. LOL
Old Jul 1, 2013 | 02:19 PM
purgat0ry's Avatar
Still haven't found the 01 forum? it's here.
Aside from that, most of these test are VERY simple and don't consume a lot of time, or effort.
The test you don't perform is the test that diagnoses your issue.
It's like old WW2 type stuff, the job you don't do properly is a victory for Hitler.
verynew2honda
Honda Civic (2006 - 2015)
Jun 14, 2013 04:30 PM
Bruce_Leroy__
Oct 16, 2011 10:53 PM
JDM215
Nov 18, 2010 11:39 AM
Beach Accord
Nov 18, 2004 10:13 AM
TimsTeg
Apr 24, 2003 04:32 PM
