Crx check engine light
Old Jun 14, 2013 | 02:13 PM
DamnThatsRexy's Avatar
Default Crx check engine light
If I drive my CRX for a long time(about an hour or more at 60+ mph) the check engine light comes on. It oly happens then. Never when I'm just driving around town. It is all stock so no mods are causing it, are there any things to check that normally cause this?
Old Jun 14, 2013 | 02:36 PM
crxguy406's Avatar
Default Re: Crx check engine light
Pull back the carpet by the passenger foot well, then bring a friend along next time you will be driving that long. Once the check engine light comes on, have your friend look at the ECU under the carpet there and count how many times he sees a red light blink... that is your engine code. Once you have the code we have something we can work with.
Old Jun 14, 2013 | 02:40 PM
24TEN's Avatar
PHANTOM MENACE
^Don't need to wait for another long drive, once the CEL comes on the ECU will store the code until it is reset.
Old Jun 14, 2013 | 04:25 PM
How do you check the ECU to see what code it is?
Old Jun 14, 2013 | 06:31 PM
24TEN's Avatar
PHANTOM MENACE
See post above mine. "crxguy406" explains how to do it.
Old Jun 14, 2013 | 06:35 PM
Will it be flashing continuously or only when activated or what
Old Jun 15, 2013 | 02:13 PM
24TEN's Avatar
PHANTOM MENACE
Key on II and it should blink if there's codes stored.
Old Jun 15, 2013 | 04:23 PM
Ok it blinks 12 times do you happen to know what that means?
Edit, I found what it mEans, thanks for your help guys!
Old Jun 17, 2013 | 09:58 PM
turn&burn89's Avatar
egr valve, my ef has the same code and i have a stuck egr valve so....
rhdins
Jun 11, 2008 10:13 AM
SmogKing
Aug 3, 2006 12:48 PM
importdude2000
Jul 17, 2004 12:53 PM
type Gendy
Apr 21, 2003 04:48 PM
