ABS motor running constanly on 1991 Honda. Help please
I have a 1991 Honda Accord SE which I bought in 1998. I have never depended on the anti lock brake system probably since I learned how to drive in the snow/ice without it 20 years earlier. Recently, the ABS motor runs for 5-10 minutes and when it finally shuts off the ABS light comes on. I would much rather have the light than the motor sound but I don't know how to make it stop. If I found the fuse and disconnected it would this make the motor stop?
Just to ease your mind I am also a school bus driver and know how to stop my bus in the ice/ snow without anti lock brakes so I am not in danger of a crash because of disconnecting this.
Thanks for any help you can give me
On the 94-97 cars inside the engine bay on the right inner fender(it will be left to you when facing the engine bay) there will be a few Fuse/Relay boxes. One should have the 'ABS RELAY' or 'MAIN ABS RELAY' If you pull this out it should prevent the motor from running. Although I do not know if this would cause any problems with the ABS light.
When this problem first started adding fluid did make the motor run less but not anymore. I keep it full nonetheless.
What about on a 1991? You don't happen to have a picture do you?
I'm fairly sure it's well marked. Pop hood, look at the fuse/relay boxes(most likely black plastic) there will most likely be raised lettering on the case if not open them up and there will be a diagram/labeling of what each fuse/relay does.
It will be rectangular or L shaped.
AlexPkring
Feb 14, 2003 10:05 AM
TWINTURBO
Mar 7, 2002 07:07 AM
