00 Civic Hx bogging during idle
Old Jun 13, 2013 | 07:34 PM
Kron1116's Avatar
Default 00 Civic Hx bogging during idle
Greetings,
Having an issue with my 2000 Honda civic HX. I drove the car around and warmed it up, parked it in my driveway and let it idle. It seems to have small bogs or hiccups throughout the duration of its idle, like small drops in rpm that are a tad violent every 5-10 seconds. I've cleaned out the IACV about 2-3 months ago, all consumable ignition components have been replaced in the recent 3-4 months. I have messed with the tps before, could it be affecting this? (I would think high or low idle but not bogging.) Any help is appreciated. I also just recently completed a valve lash adjustment to spec.
Old Jun 13, 2013 | 08:07 PM
B_Swapped93's Avatar
Default Re: 00 Civic Hx bogging during idle
when you say "messed with" what do you mean ?
Old Jun 14, 2013 | 09:33 AM
Kron1116's Avatar
I replaced it a while back (a year ago?) because I was experiencing extreme fluctuations in rpm while driving on the freeway. I don't know if I have it set at the correct voltage though.
Old Jun 14, 2013 | 12:38 PM
you have to calibrate it.
Old Jun 14, 2013 | 12:46 PM
Former User's Avatar
This^
Any CEL codes?
Old Jun 14, 2013 | 01:14 PM
Kron1116's Avatar
Understood. Would, it affect the idle like this after not being properly adjusted for this amount of time? It hasn't been like this and the tps has been in the same position. I also have an exhaust leak near the ca
t. Could back pressure affect it like this? I also read bleeding air out of the coolant could help? Also no cel atm, although it was on a few days ago but the battery was unpluged and the cel has stayed off since then. The code was due to a heavier wheel switch (hx rims to gsr blades.)
Old Jun 14, 2013 | 01:17 PM
What codes were thrown prior to you resetting the ECU?
StillBaggn
35
Aug 26, 2014 07:35 PM
Alexpbnj
Nov 16, 2010 03:48 PM
77Aerocoupe
Feb 23, 2004 12:22 AM
